2003 Toyota ECHO Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant fit drums over pads
Replaces everything new and i cant fit drums over pads. i can drive them in but then cant spin wheel. e-brake is off and even with it disconnected drums still wont fit.
Anonymous
Level 3:
  • Toyota Master 1,861 Answers
  • Posted on Apr 06, 2009
Anonymous
Toyota Master
Level 3:
Answers
1861
Questions
23
Helped
1483926
Points
8422
You need to retract the brake shoes, via the center adjuster mechanism. As your old brake wore, the adjuster moved the shoes outward. Simply move the adjuster to retract the shoes, then slide the drum on. Then, readjust the rear shoes.
4helpful
4answers
Why do the rear wheels get very hot at hwy speed after only 20 mi?
Replace the rear brake hose/s. They deteriorate on the inside and clog up. Not letting the calipers or cylinders to release. I recommend replacing the front and rear.
1helpful
2answers
1993 Ford Taurus drivers side rear wheel cylinder piston is popping out
Your description sounds like the brakes are WAY out of adjustment. The brake cylinders need the shoes to hit the drum or they will do exactly what you describe. I always adjust the shoes until they lock the wheel, then back off until the wheel spins freely, usually 8 to 20 clicks.
Did complete brake job on 1997 Ford Escort wagon no abs rear shoes, drums, lines, wheel cylinders,even changed the block at the rear were the lines go in & out of. Front lines hoses pads, caliplers...
is brake pedal hard to push down without engine running ,if so proceed to step two and thats to start engine and then push on brake and if pedal softer to push then the servo is working ,now if excessive pedal travel with engine running then remove the rear drums ,make sure the outside lip is cleaned out and then adjust the brake shoes manually till they rub when you turn the drum ,this will cure it but remember that it has to bed in of course new pads brake disks ,new shoes and drums it has to bed in so give it a chance .
I put new brakes in my saturn. i put new front calipers,rotors and pads and power bleed front only. i also put new brake pads in rear but did not replace drums.after all that i can't get a hard brake...
try adjusting the rear brake shoes but.....spin the rear wheels first is u get the feeling of the shoes grabbing then releasing ( the tire gets loose then tight as u rotate it) u will need to have the drums cut on a brake lathe or replaced...when u have this done , then adjust the rear shoes until u get a slight drag on the rear wheels..go pump the brake pedal to seat the shoes if the wheel spins free adjust the shoes more an repeat until they have a slight drag after pumping the brake pedal
5answers
I hear a loud scaping noise from my 2005 Toyota camry when i press on the brakes.
Sounds like the brake pads may be worn out in the front. Make sure that there is not metal to metal contact that may score the rotors. Also, check the shoes and drums for the rear brakes if so equipped.
If you need instructions on how to disassemble, let me know.
2helpful
3answers
My left front wheel squeeks until i press the break pedal
Most likely the brake shoe in that wheel is worn down to the rivets and those metal rivets are scraping on the drum. If you have a new brake shoe installed right away you will be ok. if you wait, you may also have to have the drums turned. By the way brake shoes come in pairs so they will change both front brake pads. Joe
2answers
Back brake drum won't go back on
check to make sure that you did not put both primary brake shoes on one side. it is common for the rear brake shoe to be a little larger than the front and sometimes a little thicker.
Toyota Camry 2005-Brake pads noise problem
The rear brakes should last from 30000 to 60000 miles or 50000 to 100000 kms. So something is wearing out your brakes too fast. Are you doing the work or some shop. I also assume you have discs and not drums since you mention pads and calipers. I am not certain but usually you need a tool to turn the pistion in when putting in new pads. I would make sure the pads are releasing properly by raising rear of car, stepping on brakes a few times (with engine off and try see if wheels are free by spinning by hand, also try to use handbrake a few times and release it and see if wheels spin freely. Maybe rears always applied. Notice burning smell, are discs glazed from heat? Are you using really cheap pads. Also check the proportioning valve which will decrease pressure to rear brakes during hard braking. Do you notice rear wheels squeling during hard braking. Do you have antilock brake system? Also are you using good quality pads and rotors.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
