Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine won't start, doesn't seen to be getting gas.
Engine won't start. Doesn't seem to be getting gas to the carb. I replaced the fuel filter, cleaned the air filter, no change. I poured a fair amount of gas into the carb to fill up the bowl and the engine started right up and ran great about 30 seconds and then died. I tried this several times with the same result. The replacement fuel filter is clear and while the motor was running, I noticed no fuel appears to be moving through the filter. Could this be a fuel pump problem? Would a fuel pump kit resolve this issue?
    Problem Solver:
  • 10 Answers
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
Posted on Dec 31, 2013
SOURCE: gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Posted on Apr 08, 2009
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
  • 15 Answers
SOURCE: Fuel problem on Sanderson 623 teleporter
Wow.....I never knew they made DIESEL lawn mowers. Sweet!
But I tell you this, I can almost guess to a "T" they have the same problems a Cat C-15 475HP diesel motor has when she runs out of fuel, and which you already done.
Air Lock. Like you just said. I seen it many a time with those motors (truck driver here). I have seen them fight you time and again on bleeding air out as well, even having done it 8 times in a row, and taking 15 minutes.
What we used to do, is simply pull the air filters, and give her some Ether shots to get moving (rough idle) and get them to KEEP pulling fuel (and air too), and THEN bleed out the air. The point is to KEEP her running, and KEEP on bleeding, until she stops fighting you.
Worked every time. Though......don't empty much Ether into her, just AIN'T good for the cylinders, man! (I have seen some guys make those motors SCREAM off of 2 cans of Ether at once. The horror! The pain!) But the motors kept on motoring!
If you can keep her running off of just the Primer, then pump away dude, and bleed at the same time.......
Posted on May 30, 2009
  • 218 Answers
SOURCE: Engine runs like POP-POP-POP.Fuel solinoid?
Hi..my name is Keith...this is kind of a hard one to answer...when im not there...but i would suspect weak fuel..i would drain the tank and put fresh in and a new fuel filter..and if that dont help..then you might need a carb cleaning or overhaul..i hope this has helped..if not..write me back
Posted on Jul 01, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
77dodge is only starting when my foot is all the way down on gas once I let go it turns off don't know why opened the choke it ribbed up but soon as let go of gas off
Engine runs for a short while then quits. - CarGurus
www.cargurus.com > Questions > Dodge > Power Wagon
CarGurusOct 28, 2013 - It starts right up and runs slow or fast for a short whil... ... Ok, when it dies look down the carb air horn and work the throttle ... of my toys for 40 years .. quite frankly I just don't know what six way power seats have to do with this guy's problem ?.... my 77 dodge doesnt have spark all new cap rotor plugs wires ...
All comments on Fixing A Car That Cranks But Doesn't Start ...
https://www.youtube.com/all_comments?v=064Ilsz8Fzg
my Chevy van does this I replaced the fuel pump but it still cranks and won't start.. Read more .... She went into a store and came out to a car that only cranks, but nostart.I sprayed starting .... Fresh gas and gas all the way up to the fuel rail. ..... A few hours later I was able to start the van again but then it shut itself down.
Engine won't start - almost no fuel to carburetor - Classic ...
www.classicwinnebagos.com > ... > Tech Talk > Chassis > Chevy (GMC
Feb 25, 2013 - 25 posts - ‎13 authors
Amazing with little starting fluid the engine wants to run, but nothing else. .... If that's the case, is my only solution is to open-up the carb and clean, ... You need to take the tank down too, to make sure it doesn't have a lot of junk in it. .... it shot a stream of gas all the way to the radiator support, about 26"... it's ...
Intro for a New RV and Newer Owner
Nov 4, 2012
Chrysler Electronic Ignition System
Aug 13, 2009
More results from www.classicwinnebagos.com
Worst Stuck Story? [Archive] - PlowSite.com™ -
Jan 03, 2016 | Cars & Trucks
My car turns over but won't start, when started
The year make and model would be handy to know.
You would need to check the fuel system and find out why you don't have fuel to the injectors or carb.
Oct 08, 2012 | Cars & Trucks
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
I have a 50 cc tao tao moped that's when I started
Make sure the cable is hooked up on the carb slide inside the carb.
Oct 10, 2017 | 2004 Factory bike Chrono SM 250
My scag turf tiger won't start. What should I do?
jump it with your car if that doesn't help jumper the safety switches on at a time check to see if there is spark spray some starting fluid and see if its a fuel problem if fuel see if gas is getting to the carb if gas getting to the carb check the solenoid they stick closed its on the bottom of the carb
Apr 27, 2012 | Garden
18.5 hp Briggs & Stratton no spark after running out of gas
I believe you are right about heat induce electrical problem.
About all there is for ignition is the coil and breaker points.
Mar 05, 2017 | Briggs & Stratton Measuring Tools &...
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
304 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
