Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Kohler cv491s Motor won't start. I replaced the fuel filter. Cleaned the air filter. Poured a fair amount of gas in the carb, opened the thottle to allow the fuel to enter into the bowl. Started the engine and it ran normally for about 30 seconds and then died. I have done this several times with the same result. Could I have a problem with the fuel pump. Would a fuel pump kit resolve this problem?
    Novelist:
  • 212 Answers
It could be fuel pump or carburetor. Make sure tank valve is open (if equipped), remove fuel line from carb and carefully have someone turn engine over, if you get a good stream coming from line you know pump is good, then you know problem is in carburetor. Hope this helps.
Posted on Jul 22, 2013
SOURCE: gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Posted on Apr 08, 2009
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
SOURCE: Craftsman riding mower, 21hp B&S starts and dies
Try removing fuel bowl under carb and cleaning it. Junk and condensation can collect there. I had same problem. Did that and problem fixed.
Posted on Jun 20, 2009
  • 218 Answers
SOURCE: Engine runs like POP-POP-POP.Fuel solinoid?
Hi..my name is Keith...this is kind of a hard one to answer...when im not there...but i would suspect weak fuel..i would drain the tank and put fresh in and a new fuel filter..and if that dont help..then you might need a carb cleaning or overhaul..i hope this has helped..if not..write me back
Posted on Jul 01, 2009
SOURCE: Popping out exhaust, loss of power, wont run at full throttle.
I had the same problem. If it is a 2 cylinder, remove the valve covers. On one side, the rocker arm had slipped off of the push rod. It was real loose. Put the rocker arm back on the push rod and tighten it down. I think this will do the trick.
Posted on Sep 01, 2009
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
My cutoff saw won't start, compression is good, has oil/gas mix, gets spark from wire but sparkplug was dirty so i cleaned it and she still won't turn over
If the saw briefly runs when you prime the carb and/or cylinder with gas then most likely fuel is not getting thru the carb. Try rebuilding the carb and replacing the fuel filter first. You can also search on youtube and google for troubleshooting tips.
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
Sears 6 hp will not start
i would look more at the needle and seat (the little valve that aloows the fuel into the carb)
Apr 24, 2012 | Sears Garden
Scooter sat for a year; wouldn't start; replaced battery. filled with gas. cleaned spark plug. won't start. Help
after a year sitting idle chances are that the gas inside the carb has degraded and the carb will need cleaning also when you filled the tank did you remove any old fuel? if not the its contaminated with the old gas
give it a full service new feul clean carb clean air filter then it should start
hope this helps
john
Jun 30, 2011 | Aprilia Scarabeo 50 Four Stroke...
Craftsman 1438766000 Mower, carburetor problems,... Mower will start using either and will run as long as I am pumping gas in with a spray can,... took out and cleaned the carb, replaced the 2 small O...
I had this problem with my Rover Mower a while ago. It nearly drove me mad trying to figure it out. And then I did the only thing I hadn't done so far. I cleaned out the fuel tank. And sure enough, there was a fair amount of gunk in it. And I also cleaned out the filters while I was going...no problems ever since
Apr 08, 2011 | Garden
I have a John Deere LT133 w/13hp Kohler motor. Problem
I had the same mower in my shop with the same prob. Last week, here is what i did to correct the problem, take the fuel line apart at the fuel filter, open the fuel cap and drain the gas from the tank, once it stops i took couple old walmart bags and compressed air to slowly blow air in to the tank to blow the residue and trash out of the fuel tank. Next using compressed air to blow through the fuel line from where the filter was toward the carb. Next unbolt the carb and remove the fuel bowl, take the small pin holding the float out and slowly remove the float pulling strait up as the needle will be attached via a small channel on the float. There is where you will find the seat which the needle you extracted sets in to stop or allow the fuel to flow. Clean these parts and area WELL. i usually take the air screws out and use carb cleaner to clean those areas as well. Reinstall the needle and float, pin assembly and the bowl. Reinstall the carb , and make SURE to install a new fuel filter not exceeding the last filters micron flow, double check all connections, clamps, and hardware, add new FRESH gasoline with no less than 89 octane at any time, engine should fire and run as intended.
Mar 07, 2010 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
