Question about NiceCycle Honda CBR 600 F3 1998 "Front" Custom Brake Line KIT 2 Lines
Having problemas after changin my spark plugs
I changed my spark plugs but now its only working on 3 i dont know if they are tight enough or too tight
    Sergeant:
  • 287 Answers
Check the plug gap to be sure they are correct and make sure the insulator are not cracked.
Posted on May 05, 2013
Car starts and drive 1 hr stop and won't start sounds like no gas but has gas in it
Does it stop itself or that were you who turned engine off?
Apr 24, 2015 | Cars & Trucks
Hi !! I have a problem with my 2004 Ford Mustang. I was changing the spark plugs and acidentally oil whent down in the cylinder. What can I do to fix that problem ?
Leave plug out and spin the engine over it may start but just turn off. All oil will shoot out put a rag over plug hole. You will be in great shape oil won't hurt the cylinder. dONT put plug in or you could hydro lock the cylinder and break the connecting rod
Feb 04, 2015 | Ford Cars & Trucks
Rethread spark plug
I really can't unravel the logic behind this. What do you want to know exactly?
Apr 17, 2014 | Nissan Altima Cars & Trucks
Xterra distributor
More likely bad spark plug wires
Feb 19, 2014 | Cars & Trucks
How do I get to the 5th spark plug on a 1990 E-150 5.8L V8? I can fill the spark plug wire. it just I can't find out how to get to the spark plug to take it off and change it with a new one.
you may hav to take some surrounding hardware of-it may be difficult cause of special tools-try not to break something either--on my camaro it took 3 hrs!---alot of times plugs dont need changin cause of better tech then the 70s--chec plug wires and distributer for wear 1st
May 26, 2010 | 1990 Ford Econoline
Why is there fuel on my spark plugs.?its an 2.8
I dont know about fuel but if it is actually oil, heres what that can mean. Oil is leaking past the worn valve guides or piston rings into the combustion chamber. Causes hard starting, misfiring, and hesitation. I recommend checking and fixing any problems with the guides or rings and changin the spark plugs once you find the problem. Please let me know if this helps and please rate my response for me. Thank you
Apr 09, 2010 | 1988 Chevrolet Camaro
Spark plug wires
yes you didnt finish the job...you always replace all plugs /plug wiring and inspect coil terminal which there should be four . trace out each individual wire and you'll find the coils. go with a good name brand transmission dextron 111 type fluid. For plug dont let anyone talk you into buying any type of fancy spark plugs use the factory recommended perferablly NGK i like that brand and have never had a problem. always put a small coating of engine oil on the threads before you install this will help get it out easier for next plug change, and never torque down on the spark plugs, especially if it has crush rings attached, just snug them up all finger tight first as good as you can get, then snug up tight with a wrench, then a good 1/4 turn should be good enough.
Apr 08, 2010 | 2003 Mitsubishi Galant
Plugs treadings
Yes there is a Nice, professional fix for your issue. You will need to call an autoparts store, or take the plug to a hardware store and figure out the thread pitch and plug diameter. If you give me the application I can look this information up for you. HEre is the source for the kit, its very easy to do, and if you take your time, the fix can be done without damage to engine. The kit will come with instruction on how to use it, however the KEY thing is to use wheel bearing grease, and constantly clean your tools after a 1/4 turn or so, to keep metal shavings entering the cylinder to a minum. Also what you need to do is change your spark plug changins tactics. When you change a spark plug first off all the engine must be cold. Allow it to cool 6-8 hours before removing spark plugs. Secondly always hand tighten the plugs before using a ratchet. Last but not least- use a torque wrench to torque the plugs to spec. Following these 3 steps you'll never have an issue. I can walk you through step by step once you get the kit. I use them allot at work, and I assure you that they are the highest quality on the market.
Sep 21, 2008 | 1987 Honda Accord
NiceCycle Honda CBR 600 F3 1998 "Front" Custom Brake Line KIT 2 Lines Logo
61 people viewed this question
Top NiceCycle Cycling Experts
John Egan
John Egan
Are you a NiceCycle Cycling Expert? Answer questions, earn points and help others
