How do i hook up rabbit ears to vizio tv for local channels
SOURCE: No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Posted on Aug 08, 2006
  • 52 Answers
SOURCE: tv repair
Your tuner (in the tv menu) is probably still set on "cable", but it should be set on "off air" or "antenna". When you first turn it on, it looks for a cable signal and when it can't find one, it automatically searches for an "off air" or "antenna" signal. Once it finds a signal, then it stays on and runs ok. If you shut it off, then it has to go thru all this again.
There is a very high probability that this is your problem (about a 99.99% chance). Just go into your menu and select "tuner" or tuning or "input select" or something in that "neighborhood". Different TVs call it different names, so just put in on the option other than "cable". If you ever get cable back again, then, of course, you have to go back into your menu and set the tuner to "cable. Hope this helps.
Keever
Posted on Mar 08, 2008
  • 360 Answers
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Posted on Jan 29, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Posted on Feb 19, 2009
SOURCE: Can't get one local channel when hooked up to T.V. antenna
Take a gun and shoot your self.
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
TV freezes up when turned to channel 33-1
I had the same problem. I also use rabbit ear antenna , no cable or satellite. I was watching ch. 33.1 and the tv turned off by itself. The remote wouldn't work. The power on/off buttons on the side of the tv wouldn't work. I had to un-plug the power cord to turn the tv off. The tv forze on ch. 33.1 when I turned it back on.
I called Vizio, they told me they received hundreds of complaints from people in Texas complain g about these problems.
I was told to un-plug the antenna cable and re-plug it. I did this plus I re-scanned all channels. The problem has been solved, the channel (33.1) no longer freezes and the tv doesn't turn off by itself.
Hope this helps.
Aug 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Cancelled dish & hooked up rabbit ears. no local channels
Digital channels require a really strong signal to work well compared to analog. Can you get any analog channels through the tv itself? You will probably need to get a large antenna mounted outside to get these channels to work especially if you are a distance outside the city from where the broadcast is coming from. Sorry for the bad news. It is one of the bad things about the digital transition.
Benjamin
Mar 25, 2009 | Insignia Digital-to-Analog Converter for...
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Sony TV KV-32v26
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Sep 20, 2007 | Sony KV-32V26 32" TV
Televison & Video Logo
671 people viewed this question
Top Televison & Video Experts
Electro Med Services...
