Question about Philips DC220/37 Docking Clock Radio for iPhone and iPod
My Philips iPhone/iPod dock won't turn on
I went to turn on my iPod and it wouldn't work. I tried unplugging it and still nothing well turn on.
2 Suggested Answers
  • 7 Answers
SOURCE: My Philips GoGear MP3 won't turn on. Is there
(I "ASSUME" you charged it, or tried to). HOW OLD is your MP3 player??
If it's pushing 2yrs old, or played/used on a fairly regular/daily basis,
.....YOU MAY JUST NEED A NEW BATTERY.
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY. FIND/MATCH BATTERY TYPE. (look in WATCH batteries).
Place the new battery in player. Close case, restart/turn on player.
Posted on Nov 10, 2011
Iphone 5 does not charge, nor does music come through the speakers when connected to the Jensen 205i docking music system via 8 to 30 pin adapter.
Hello Karan,
Thanks for choosing a Fixya.
As far as i know & from experiance of using Apple Product since many years, some times some accessories does not supports & works very well with iPhone. If your iPhone is working fine with other accessories that mean original accessories came from Apple then there is nothing wrong with iPhone, so please try it with another system or try with another 30 pin Apple original dock adapter & i hope it will work like charm.
Thanks & Regards,
Chandrashekhar !!
Aug 20, 2013 | Jensen JIMS-205i Docking Digital Music...
I have an lg home cinema and docking station GT462DZ . Sometimes, when i try to dock my ipod touch in it , it says 'check ipod' and it won't play music . It won't work. I always restart my...
It could be that some dust or something has got inside the dock and giving a bad connection. Check both devices for damage to the dock connections.
Feb 15, 2018 | Audio Players & Recorders
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
I have a Sony Dream Machine ICF-CS15iP Personal Docking Station. It won't play the iPod music through the speakers of the docking station.
I have the same radio and the exact same problem. I reset the radio and it wirks for a day. I go and try my iPhone the following day, and reverts back to error this device does..... Well you know the restored of resetting this thing every other day.
Sep 05, 2012 | Sony Dream Machine FMAM radio with...
IPhone not recognised when docked
Try a different charging dock make sure it puts out the same volts as the iphone has
Oct 03, 2017 | Philips Audio Players & Recorders
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
Why wont iphone communicate with the ipod station
Have you made sure that there is no protective case on your iPhone that would be interrupting the connection between the two devices? Have you verified that your device is compatible with the dock? On most of the new ones they require a digital input from the iPod/iPhone which only iPods made in the past few years (2007 or later) can supply. Also try docking your device when the docking station is in standby mode.
Dec 25, 2011 | Philips DCM250 Table Stereo Clock Radio...
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
IPod Touch 4th Gen will dock. Will Charge. Can use remote control to play, and shuffle songs from iPod, but sounds will not come through speakers on Philips SBD8100 Speaker Dock for iPod and iPhone
Hi Sniper326,
try cleaning the input socket of the Philips Speakers with a cotton bud, try cleaning the socket of the Ipod touch cable as well.
Have you tried using the IPod touch with different speakers? and does it work? if so the problem lies with your Philips speakers.
I hope this helps, good luck!
Mar 15, 2011 | Audio Players & Recorders
Philips DC220/37 Docking Clock Radio for iPhone and iPod Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
