Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
Mono wiring i have an pioneer cd player w/sub pre out,single 10'memphis sub in sealed box.i would like to know about wiring the amp in mono such as rca r/l or both inputs and speaker wiring.
  • 113 Answers
Leave rca as it is,only speaker config is needed there should be an illustration printed beside the connectors that says bridge
Posted on Aug 09, 2007
Need a wiring diagram to hook up two 10 inch subs and 15 inch sub a kicker 250.1 amp
Series or parallel? Single, dual voice coil? I'm not sure you have the right size amp for all 3 speakers. And I wouldn't wire the 10's together with the 15. The larger sub is going to have a larger power demand. You could wire the 2-10's together on this amp, and get another mono amp for the 15.
Oct 02, 2014 | Car Audio & Video
Sub hook up to Receiver
If the Pioneer has only one sub output connect it via a single RCA to the mono one. If it has two outputs (L&R) connect it to the L&R on the sub via a dual lead.
The other connections on the sub are for those amps without a dedicated sub output.
The manual for the sun can be seen online.
Yamaha YST SW205 Owner Manual Connections Connecting To Line Output pin...
Dec 18, 2017 | Pioneer VSX-454 Receiver
Were is the sub woofer tie into at.
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
May 11, 2011 | Pioneer DEH-2400F CD Player
Can a pioneer DEH-46DH super tuner be hooked up with subs? using its pre out?
Yes you can use the pre out to hook up an amp and subs. Probably the best way to send the signal to an amp to run the subs.
Sep 20, 2010 | Pioneer DEH-46DH CD Changer
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
My subwoofers ''fight'' each other
YOU ARE CONECTING ONE OF THE SUBS ON THE INCORRECT MODE SO DISCONNECT ONE OF THE SUBS AND SWAP THE WIRES AND TRY.
Mar 23, 2009 | Car Audio & Video
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Wiring 2 subwoofers to a mono amp?
The subs can be wired "parralel" or in a "series". it depends on the ohm rating of the speakers and the amp. Most amps can only go down to 2ohms (mono) so it depending on the ohm ratings of the speakers when wired in a series vs parralel that will decide how to wire them. you can always take the safe route and just wire the positives of each to positive on the amp and the negatives to the negatives on the speaker terminals. Do you have the speakers model numbers?
Dec 14, 2007 | Car Audio & Video
Car Audio & Video Logo
74 people viewed this question
Top AudioBahn Car Audio & Video Experts
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
