Question about Kenwood KDC-X493 Car CD/ MP3 Player
4runner wiring Doesn't turn on
  • 54 Answers
Hi chandler, if your yellow, red and black wires are "correctly" and securely connected then the rest of the problem lay inside the unit. also try resetting the unit. cheers.
Posted on May 05, 2013
I'm installing power seats from a limited 04
get a haynes or other repair manual-partsplace or internet--also ur library sec629 has an auto reference of mitchell and chliton--if these dont doit getta pro mechanic
Aug 13, 2013 | Cars & Trucks
Starting issues with Toyota 4runner 2000
Without seeing the car I won't know this for certain, neither will anyone else here.
Try checking the MAF sensor. If you have a diagnostic tool, check the resistance at low throttle and high throttle. You are looking for a consistant change in resistance over the angle of the throttle. If it doesn't seem consistant, then this might indicate a fault with it.
Nov 03, 2012 | 2000 Toyota 4Runner
Tail and panel light doesn't turn on. fuse keeps burning
You have a ground issue.Current from another circuit is running through the lights to get to ground. this causes them to burn out quickly.You need to do a real detailed visual check.A good component wiring diagram and component locator is a requirement here.
Sep 11, 2012 | 1998 Toyota 4Runner
My 1995 4runner backdoor or window won't open
Does the back interior light work? if no, chances are you have the #1 problem with back windows in 4runners, a connection under the back door panel, works itself loose, just plug it back together tight.otherwise check the fuse.#2 if that doesn't work did you bump into the back door, motor placement is sensitive to dings, and gets stuck. if not those prob a motor? i think i am not a mechanic.
Sep 07, 2012 | 1995 Toyota 4Runner
1999 toyota 4runner keyless remote doesn't work
Check with a Toyota dealer for your info
Aug 30, 2012 | 1999 Toyota 4Runner
I have a 93 4runner v6 manual. I went to turn the heater on the other day and no air was coming out of it but when I started driving down the freeway air started coming through the vents. When I stop
sounds like your fan is either jamned, burnt out or even frozen, you might be lucky and find its just a blown fuse, you'll need to check your fuses box then start investigating if the fan turns freely or not
if you put the air on recirc you might be able to stop cold air blowing in when you are travelling. if you are waiting for a garage to sort out the fault then get a fan powered by the cigarette lighter, air moving over the window should at least keep mist clear even if it doesnt defrost it
Nov 09, 2011 | 1993 Toyota 4Runner
1998 4runner trailer light wiring not working
I recommend that you tighten the ground wire screw for starters. since the vehicle is ten years old corrosion may be the culprit.
Feb 01, 2009 | 1998 Toyota 4Runner
Kenwood KDC-X493 Car CD/ MP3 Player Logo
44 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
