Install transfer unit
Replaced Transfer Unit but alarm message still prompting.
  • 214 Answers
SOURCE: transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Posted on Jun 19, 2008
SOURCE: Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Posted on Sep 15, 2008
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Posted on Oct 01, 2009
Bizhubman
  • 108 Answers
SOURCE: how to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Posted on May 17, 2010
Installing samsung clx6220 image unit
See page 103 of http://downloadcenter.samsung.com/content/UM/201112/20111205134621713/EN/English.pdf. It looks like the clx6220 uses a transfer belt to transfer all the different toner powders to the paper.
see
http://www.genuinetonercartridges.com.au/genuine-samsung-clp-620nd-clp-670nd-clx-6220fx-clx-6250fx-page-image-unit-transfer-belt.html
The transfer belt unit is refered to also as the image unit !
Also each toner cartridge contains the OPC drum and is replaced when you replace a toner cartridge by the look of it.
You need a transfer belt to transfer the image to the paper and this is why they call it an image unit.
I am guessing that the transfer belt needs replacement !
Sep 08, 2014 | Samsung CLX6220FX AllInOne Laser Printer
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Apr 12, 2012 | Xerox DocuColor 3535 Copier
Fuji Xerox Docuprint CM305df user manual
I have a Fuji Xerox CM305 df, it raised an alarm to Replace Transfer Unit, I've replaced that but the alarm/message is still active, how do I go about now??
Feb 21, 2012 | Fuji Office Equipment & Supplies
My 4700dn is giving me the replace transfer kit message. I have swapped out known good transfer kits and the printer prints fine but I still get the replace transfer kit message. What can I try next?
The message only clears when you install a new transfer unit, one that hasn't been used before. If you want to clear the message, you'll have to install a brand new transfer belt.
If you know the service PIN for the 4700, you can probably go into the service menu and clear the message, but otherwise a new transfer unit is the only way to go.
Aug 11, 2010 | HP LaserJet 4700 Printer
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
A new installation is not detected when a new
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a ricoh 1022 giving me an erro message "Funtional problem within copier" code sc402. can you send me step by step to fix this problem?
Transfer roller leak error negative electrode.The feedback voltage of the transfer roller is insufficient.Verify the correct instalation of the transfer unit or the separation unit.Check and clean the transfer roller.Verify the connection of the PCU unit(loose).
Nov 21, 2009 | Ricoh Office Equipment & Supplies
Transfer unit
You need to reset the counter, instructions should have been in the box.
Jan 15, 2009 | HP LaserJet 3700n Printer
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
jasbo
jasbo
