Question about Carrier 38CKC036 Air Conditioner
How old is my air conditioner
Model 40A0024300BU Ser. 1087A12923
Need replacememnt shroud duo therm ser no e7172569 yr 1997
I may be abler to get you one and send it to you. but only if the unit is less than 10 years old or less. if over 10 years the cover may no longer be available.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
Need to know the tonage
Hi You have a 4-ton unit or 48,000 btu per hour cooling
Nov 08, 2011 | Ruud UBHC Air Conditioner
How do i know the tons and seer of my york unit model h4db060s06a ser #wglm032b12
That is a 5 ton system but I do not know the SEER rating. See that 060 in the middle of the model number? That means 60,000 BTU or cooling capacity and that is 5 tons.
Jun 20, 2011 | Carrier 38CKC042 Air Conditioner
How old is a ruud furnace model number ugaa- 08KC, ser. number RN3D104F18794988
Hello, The model number for Ruud/Rheem equipment is located in the 12-13 digits, these appears to be a 1994. I have seen some furnaces with an age older than when the home was built (a 1995 furnace in a home built in 2000), so good job checking the serial number. This gives you the age it was manufactured.
Hope this helps James
Apr 03, 2011 | Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
COMPRESSOR Amana / RCE24C2A Ser #036142440
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
Jul 12, 2009 | Heating & Cooling
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Carrier 38CKC036 Air Conditioner Logo
63 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
