Question about Bosch 1997 Volkswagen Jetta GL 2.0L Professional Preferred
No power to injectors 1997 gl jetta - Bosch 1997 Volkswagen Jetta GL 2.0L Professional Preferred
1997 vw Jetta GL Where is the fuse box?
Under the drivers side dash, left of the pedals
Dec 01, 2016 | 1997 Volkswagen Jetta
Starter wont engage because of security alarm
the simple way to get the solution is service and repair manual which will guide you to locate and fix the problem easily by yourself and to get the manual go to the given link http://toolsnyou.com/
Feb 23, 2018 | 1997 Volkswagen Jetta
1997 jetta starting promblem
its probably your starter. thats what happened to my car. also check your battery to make sure its not dead.
Dec 30, 2011 | 1997 Volkswagen Jetta
I want to adjust the idle on my 1997 vw jetta gl
the idle speed is controlled by the computer and is not adjustable, any attempt to raise it will just be overridden by the automatic system. What is the problem with the idel speed?
Oct 26, 2010 | 1997 Volkswagen Jetta
Where can I find a free online guide describing the process for replacing the clutch on 1997 VW Jetta GL 2.0
If you Google for VW forums or user clubs you might get a good one with even step by step photos.
Jul 01, 2010 | 1997 Volkswagen Jetta
I have a 1997 volkswagen jetta 2.0 GL. I just
if you added back the fluid you lost it e=will run out becuse thermostat aint o pen yet try again let motor warm up then cgk fluid
Oct 08, 2009 | 1997 Volkswagen Jetta
Hi i need to know what is the original size of the 1997 volkswagen jetta gl tires
tire size is listed in the owners manual. if it's been lost call local tire shop they have all the info on OE tire size
Sep 09, 2009 | 1997 Volkswagen Jetta
I have a 1997 VW Jetta GL. I disconnected the
Reconnect starting with positive then negative.
Jul 19, 2009 | 1997 Volkswagen Jetta
Open Questions:
Bosch 1997 Volkswagen Jetta GL 2.0L Professional Preferred Logo
18 people viewed this question
Top Bosch Electrical Supplies Experts
wadingriver
wadingriver
Steven Brandon
Steven Brandon
protojexxx
Are you a Bosch Electrical Supply Expert? Answer questions, earn points and help others
