Question about Cub Cadet LTX1045 2009 and After Deck Belt OCC75404219
.hydrostatic release dosent release..
Hydrostatic release dont release
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Proberly just needs adgusting
Posted on Nov 22, 2013
I changed filter and oil in my 1863 cubcadet hydrostatic now it dosent move
Be sure you used the correct fluid. If it is not the right fluid....it will not engage properly.
Dec 28, 2016 | Garden
Ariens model 93603900 parking brake will not release
Typically pressing down on the brake peddle will release the brake. F the parking brake was engaged with excessive pressure it my be difficult to release. You may need to "stand on it" to release it.
Aug 28, 2013 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
It dosent show that im receiving a call on myzte phone
Try to set different ringtone on your device and also check whether the volume is maximum or not. If all these are working fine then try to reset your phone to factory defaults.
Apr 06, 2013 | ZTE Warp
I have a 2008 John Deer X300 riding mower. I parked it and when I went to use it the next day would not move forward or backwards. It is hydrostatic. What could it be? How do I check fluid for hydrostatic?
Sounds to me like your hydrostatic control lever has became disengaged. If you had a fluid problem yuou would probably find fluid on the ground or within the tractor chasis somewhere. I,d check the linkages for your problem. Also make sure your parking brake is released.
Sep 13, 2010 | John Deere Garden
How do you put the drive belt for the hydrostatic drive on?
You'll be working underneath the mower, so it is helpful to raise the mower chassis up -- at least in back. Use your automobile jack, then put jackstands underneath the chassis to do this. Take off the deck drive belt first by releasing the idler spring(s). Unbolt and remove the "anchor" that keeps the PTO clutch from rotating. Disconnect the electrical wires leading to the PTO. Release the tension on the idler for the hydrostatic drive belt. Now you can thread the new hydrostatic belt over the engine pulley and around both wheel motor pulleys. The idler pulley presses it inward to provide tension. Refasten the idler spring - a pair of channellock pliers works well to hold and pull the spring. Now reinstall the wires and the PTO anchor, then the mower deck belt. Good luck! Please rate my answer if helpful, thanks!
Jul 02, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Tractor will not go into gear
is it hydrostatic or belt?probably belt broken.if its hydrostatic,check the release lever at back,that allows you to push it.wont drive if its released
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
On my cu cadet zero turn only the left side turns and the right side moans but wont move ever with the release lever to free wheel released
Check the hydraulic oil level for the hydrostat drives(if it has a reserve tank located under the seat. Some ZT's don't have the reserve tank. Don't over fill that tank. 1/4 inch above the bottom is all it needs.)
Also, check the steering arm bolts. Very often they work themselves loose and the arm doesn't pull the valve rod that controls the hydrostat unit.
Oct 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Trunk release
my trunk release button dosent work i just bought the car and it dosent have a key for the trunk?
Aug 19, 2009 | 1988 Lincoln Town Car
631 clark skid steer won't drive or steer the left side? the chain is still on the sprockets.
With all the hyd pressure released, need to unhook the 2 big hoses going to the hyd motor on the chain case on the left side and CAP OFF with fittings. Next start the machine and SLOWLEY move the travel control for the left side a little front and back, you should hear a loud growl from the hydrostat, showing that it is pumping under load. Dont do this long, but enough to test. No noise means the problem is in the hydrostat, possiably bad slipper plate, rotating group or both high pressure relief valves.If you have noise the problem is in the hyd motor. Good luck and be carefull!!!
May 09, 2009 | Bruder Cat Skid Steer Loader
Cub Cadet LTX1045 2009 and After Deck Belt OCC75404219 Logo
51 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
