Question about Rheem Complete Split System Straight Cooling 3 Ton 16.5 SEER 13 EER. RHPN Air Handler
Will not switch on
Outside unit does not come on fan blows in the furnace
  • Rheem Master
  • 16,241 Answers
There should be a box near that. Electric fuse or breaker might be in that, check it. be careful! it is high voltage. Check the other breakers too. If that is not it, let me know
Posted on May 04, 2013
My thermostat isnt kicking on my furnace. even if i use the arrow to increase it, still no heat and it isnt kicking on the furnace. even tried changeing the batteries. sometimes it will say,"return" n
Recheck that the thermostat is wired correctly. If so,switch it to fan on and see if the fan comes on if the fan does not come more then there is definitely an issue with the furnace and not the thermostat.
Feb 15, 2015 | Honeywell RTH221B1000-OB Open Box Basic...
Ruud troubleshooting
do you have the lower door in place tight ?? because there is a door button switch. so if its not pushed in all the way you would have no power at furnace. also make sure nobody turned off the on off service switch usually above furnace or sometimes one at top of stairs and one down by the furnace .if those suggestions don't work you might want to turn each breaker off then back on incase one is tripped. if that don't work check for 120 volt at your fan timer board also it may have a automotive style fuse on the board which if blown it wont do anything. if there is 120 volt at board and the 24 volt circuit fuse is good its probably the fan timer board.
Jan 17, 2014 | Water Heaters
Doesnt blow
Combination fan limit control, circuit board, motor, or capacitor is out.
Dec 12, 2013 | Water Heaters
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
Install tankless hot water
Please contact your city permit office for construction requirements, they vary from city to city.
Jul 28, 2017 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Fan come on but there is no heat, there is gas because I could turn the stove on. the Heater was working fine, but when I went to turn it on the fan will blow the air but it never got hot it was blowing...
I'm thinking the heading should be furnace so here goes. Need to test for 12 volt power at sail switch, and high limit switch as well. If you give me the model number may be able to guide you better. If you shut it down/off, and remove 2 screws holding cover on, inside your RV , you should see a model number like SF-- or NT -- on a stamp or label. Let me know if you find it and need more help.
Jan 26, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Furnace does not work
Is there a booster motor for the burner? I have seen these stick and make a furnace not turn on. The thermostat trips and you hear the furnace click on but nothing else happens. The booster is a small electric motor connected to a small duct. Take the booster motor loose and turn the fan by hand. Usually they will start working after you do this. Make sure furnace is shut off when you do this. Some booster motors have ports to oil them also.
Dec 09, 2009 | Calvin Klein The Field Controls Company...
York Dianond 80 Furnace
You have a limit switch that needs to be reset. It is probably the roll out switch that is located on the burner housing. The limit switch is a disk about the size of a dime or penny and has two wires to it. There is a small button in the middle of these two wires. Press this button firmly to reset it. Look for all the limits that may be on the unit that is manual reset like the one described above and do the same. This should correct your problem.
Apr 12, 2009 | Water Heaters
Rheem Complete Split System Straight Cooling 3 Ton 16.5 SEER 13 EER. RHPN Air Handler Logo
41 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
