Vizio xvt3d47sv unit has a "Kaleidoscope" screen
I'm building a Kaleidoscope with internal lighting. I have the lighting worked out with a switch, but I would prefer it to turn on with a sensor that detects when the kscope has been picked up.
For a non-powered solution, you could use a tilt ball switch from Adafruit to turn on the kaleidoscope when it is picked up: https://www.adafruit.com/products/173
This will only keep the kaleidoscope on while it is held in a certain position.
You can also add a flip-flop latching timer that is activated when the tilt ball switch is triggered. The kaleidoscope would then stay on for a certain amount of time. I found this on eBay, but have never used this one: https://www.ebay.com/itm/262578744921
Hopefully this helps or at least gives you some ideas. :-)
26314892-04kdaugeos4wiqiydpx4nc01-5-0.jpg Tilt ball switch
Flip Flop Latch Switch Circuit Module Bistable Time Timing Switch Module...
Oct 17, 2016 | Miscellaneous
I need an instruction book for jet laser kaleidoscope
As a rule, the manufacturer's web site will contain a support page where you can enter your printer model and download a PDF of the manual. Have you tried this?
Dec 28, 2013 | Computers & Internet
When I turn on my Vizio E 371 VlL it displays cracked screen hiding most of the picture
You now have a parts unit !!! It will cost more than a new set to get a replacement screen. Toss that puppy on Ebay or your local Craigslist as a parts unit !!!
Sep 29, 2013 | Vizio VU37L 37 in. LCD TV
Can i use a westinghouse screen to replace a vizio screen
Kenneth,
Please re-post in Electronics > Televisions & Video
The only thing I can state, is look at the manufacturer code on the back if the screen, (Westinghouse), and see if it is a replacement for the Vizio's screen.
[This is the Laptop PC category]
Regards,
joecoolvette
Feb 25, 2013 | Vizio 32" Class LCD 720p 60Hz HDTV with...
Cracked lcd panel on vizio tv/ model: E3D420VX
place unit on ebay for sale or search ebay for the same model search under broken Tv look for unit with good screen not working buy and install your circuit boards.
Badda Bing problem solved
Replacement screens are hard to find.
Jan 21, 2013 | Vizio Televison & Video
Vizio e420va no power no light
Suggest to plug unit in another outlet and run basic troubleshooting again as per user guide.
May want to unplug unit and hold power button for 30 seconds for power cycle.
May want look very closely to screen to see if you are still able to get moving images. (Backlight might be dead)
If none works suggest service for unit.
Ref: http://store.vizio.com/documents/downloads/hdtv/E420VA/UM_E420VA.pdf
Dec 18, 2012 | Vizio E420VA 42 in. LCD HDTV
I need ro gins a replacement screen for a vizio p42hs. is this possible
Replacement screens are available but it is more cost wise to replace the tv. The replacement screens are more than half the price of the unit. To find a replacement just google replacement screens for your set.
Sep 23, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
SONY PLAYSTATION 3 faults the screen is like a kaleidoscope
You have begining signs of yellow light of death and need to reflow the cpu and gpu with a hot air heat gun found on ebay pretty cheap.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Periodically the screen will start turning green, then worsen.
Per Vizio's webite( linked below), as long as you purchased the unit from an authorized Vizio dealer you have a one year warranty. You would need to contact vision to determine if the problem is a warranty type issue.
http://www.vizio.com/support.aspx?id=1588
Jun 03, 2009 | Vizio VO47L 47 in. LCD TV
50" Visio goes blank after 10 - 15 minutes, blanks on and off.
I have a 32" Vizio and i have the same problem...... I've had it for five days and I'm not happy about it......... Looks like I'll be taking it back if I can't get help...
Dec 30, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
