Question about Uniden Stealth Rt Tt 3000gt Vr4 1992 92 Radio Cb Transceiver Antenna 124,770
Misfire fail emission inspection CH ppm @ 2500 RPM TEST reading 313 allowed 220 idle RPM TEST 441 allowed 220
  • Uniden Master
  • 17,115 Answers
High HC means that it has an issue with too much fuel, not enough air.
Posted on Jun 10, 2013
1995 Honda Civc failed Emmisions test
Emission test by codes reader? or smog? Any codes?
May 22, 2017 | 1998 Honda Civic
I have 1998 GMC k1500, I took it in for Smog test in California,
slite posibility of head gasket leaking a little or could be a worn piston ring you have changed every thing else
Sep 02, 2012 | 1998 GMC Sierra
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Oct 17, 2017 | 1993 Ford Taurus
What does No ppm mean?failed e-test
Here is some info for you to read, besides me explaining what ppm is, i also gave you some info of how to solve this, Ain't that special LOL. Mike
Overall Result: PASS or FAIL. A vehicle with a properly operating engine and catalytic converter will have very low HC and CO readings. However as a vehicle ages the HC and CO emissions will increase and may become erratic. As a vehicle ages it becomes increasingly important to be sure that the engine and converter are fully warmed up before the test to have the best chance of passing the test.
HC (PPM): The parts per million of hydrocarbons (unburned or partially burnt gasoline) in the exhaust.
CO (%): The percentage of the exhaust that is carbon monoxide (CO).
CO +CO2 (%): Complete combustion in the engine or catalytic converter will result in very little carbon monoxide (CO) and a high percentage (up to about 16%) of carbon dioxide (CO2) in the exhaust.
O2 (%): When there is complete combustion in the engine or catalytic converter there is a very little oxygen (O2) in the exhaust. Usually less than one percent. A higher reading indicates a problem with the engine, the exhaust system, the sampling system or the catalytic converter. Vehicles do not pass or fail because of the O2 reading; it is only diagnostic information.
RPM: The engine speed in revolutions per minute (RPM) or N/A.
Cruise Limit: The maximum allowable HC and CO emissions at 2500 rpm. The CO+CO2 (%) must equal or exceed 6. This verifies an adequate sample of the exhaust has been obtained. N/A for O2 and RPM.
Cruise Emissions: The emission readings measured at 2500 rpm.
Cruise Result: PASS, FAIL or N/A.
Idle Limit: The maximum allowable HC or CO emissions at idle. The CO+ CO2 (%) must equal or exceed 6. This verifies an adequate sample of the exhaust has been obtained. N/A for O2 and RPM.
These are the possible problems:
bad o2 sensor
bad EGR valve
bad cat
bad timing
dirty injectors
bad plugs or wires
the less costly fixes include replacement of the o2 sensor and EGR valve i would not clean the EGR I would buy a new one there are very cheap you can pick these up at any local parts store .
also run some injector cleaner through your car at least a full tank of gas and one bottle of injector cleaner should be ran through.
you can also have your timing checked for a relatively low price.
and when you go into to have the vehicle checked make sure the car is been running because your cat convertor has to be warm in order to preform at it peak so do not do it when the car is cold.
all of the above are pretty reasonable fixes the general rule of thumb when you work on your own vehicle is start with the cheapest fix first then go on to the next.
Aug 11, 2011 | 2000 Saturn Ls 4dr Sedan
Vehicle inspection, pass primary emissions test but failed high idle test HC ppm 559. standard is 220. man at inspection said was missing at high idle,what can cause that??
First either replace or clean the idle air control valve.You can clean it with a non-chlronated brake cleaner and wire brush.Then take the mass air flow sensor off and do the same but don't use a brush just the cleaner only.
May 12, 2011 | 1999 Chevrolet K1500
My 1997 Honda Civic failed it's Emissions Test. See below the ASM Emission Test Results. What do you suggest I do to get the car to pass the smog test? ASM Emission Test Results: 15mph - RPM = 1587...
Jose, I don't know if this will give you the answer you are looking for because there are many things to consider here. The exhaust gas recirculation valve (EGR) is one of the main things involved in reducing NO emissions. This valve is controled by the power control module. (PCM) This is your vehicles computer. The PCM monitors the vehicles speed and will command the EGR to open when the vehicle attains a certain speed, which is why the ASM test being done is recorded at two different speeds. At 25 MPH your vehicle failed the hydrocarbon (HC) emissions limit and this could be for a number of reasons. When is the last time you car was tuned up? Old spark plugs, wires, clogged air filters, oxygen sensors, leaking injectors (personal experience) or the PCV valve could be contributing to the results of the test. I guess that the easiest way to go is to tune up the engine replacing the spark plugs, wires, air filter and the PCV valve and don't forget to have the oil changed at the same time. Only then should have the vehicle retested and see what the results are. Should it fail again you may have to consider having the EGR or the catalytic converter replaced depending on what portion of the test fails. If the NO fails I would consider the EGR. If the HC fails then I would consider the catalytic converter. Good luck with this.
Apr 05, 2011 | 1997 Honda Civic
Failed smog check
How well does the vehicle run?
Assuming that the engine did pass the EGR function test on the emission test results, and the MIL (Malfunction Indicator Light) or check engine light is not on when the engine is running, and if you are not sure when the last time it was that the engine had a complete tune-up, with distributor cap, ignition rotor, spark plugs, spark plug wires, air and fuel filters, then a complete tune-up would certainly help, and if the engine oil and oil filter have not been changed in a while, then they should also be changed before an emission test because long used engine oil traps carbon and it will show up as higher CO on the emission test because the emission analyzer will be able detect the higher CO from the engine oil through the PCV valve.
However, it would seem from those HC readings that there is a vacuum leak, and carefully inspect all of the vacuum lines for any cracks or damage, (especially the vacuum line to the fuel pressure regulator) because cracks in the vacuum lines seem to like to hide underneath the lines.
The emission label under the hood should have the vacuum line routing diagram printed on it, and the vacuum lines should all be checked to be certain that they are all connected correctly.
Here is the firing order diagram for that vehicle to help assist you tune-up the vehicle.
Jul 09, 2010 | 1997 Honda Civic
FAILED EMISSIONS
possible but could be head gasket or valves , or worn rings and is by passing the pistons going straight out the end ...or maby settings are wrong ? try carb cleaner and inspect visually air-filter etc.
Aug 26, 2009 | 1986 Ford Mustang
ASM 2525 NO ppm TAILPIPE EMISSIONS failure
have you had the the engine codes pulled and reset?
and if so what are your engine codes?
i dont know of any car that will pass emissions test with the engine light on.
we cure your trouble that caused your engine light to come on and you will pass your test.
later
paul
Nov 24, 2008 | 2002 Toyota Sienna
Uniden Stealth Rt Tt 3000gt Vr4 1992 92 Radio Cb Transceiver Antenna 124,770 Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
