Air conditioner thermostat
I need help connecting wires thanks
    New Friend:
Color for color should do it
Posted on May 03, 2013
  • 1033 Answers
SOURCE: goodman air conditioner doesnt turn on after nail
Hello, if there is no fuse on the circuit board than it is possible that the transformer is bad. Easy way to chevk is turn off power to unit and use a meter to chevk resistance of the transformers secondary side. If no resistance the transformer must be replaced.
Posted on Sep 26, 2011
SOURCE: Installing thermostat into my Rober air conditioner
Most typical wiring for Heat pumps are as follows: Red-R, Yellow-Y , Blue(common)- C, Green-G, White To either W, or W1, or Aux, Black-E, I will need additional info like: is your system a Heat pump, Straight a/c w/ elec. heat, and also what kind of tstat are you trying to hook up? Digital, mechanical?
Posted on Oct 16, 2007
bobicehouse
  • 1524 Answers
SOURCE: rewire air conditioner controls
Assuming "Window Unit" with rotary switch.
L1 (smooth part of line cord) to thermostat 1, thermostat 2 to overload (black disk) from overload to Common( C) terminal on compressor.
From Run (R) terminal on Compressor to Common (C) terminal on dual capacitor. From Start (S) terminal on Compressor to "Herm" terminal on capacitor. From fan motor to # 4 on switch = Medium Speed, to # 6 on switch = High Speed, from fan motor to # 7 on switch - Low Speed. Brown wire from fan motor to (F) on dual capacitor, white wire from fan to (C) on capacitor and L2 (ribbedwire) (N) to (C) on capacitor
Posted on May 10, 2009
bobicehouse
  • 1524 Answers
SOURCE: i NEED TO RECONECT WIRES TO CONTACTER RELAY ON
Power leads L1 and L2 to top terminals of contactor.
Compressor leads T1 and T2 to bottom terminals of contactor
Side terminals get the low voltage leads from transformer.
Posted on May 19, 2009
SOURCE: TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Posted on Feb 24, 2010
My air conditioner thermostat keeps losing power
The power for thermostat come to an from the thermostat with the red and common wire. Check for proper connection to thermostat and check thermostat wire from the thermostat to the air handler. Technicians sometimes do not install splices well and sometimes the splices comes loose. I prefer using rtv loaded wire nuts to make splices when I can find them. Another cause for this problem is bad insulation on thermostat wire allowing wire to short out. If this is your problem, you need to replace the thermostat wire itself. If these do not fix your problem, you may need to replace the thermostat itself.
Hope this helps
Oct 20, 2014 | Heating & Cooling
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
Hooking up the thermostat
Typically thermostats only have connections for two wires. All the switching and power control is done in the unit not the thermostat. A thermostat normally runs on low voltage, about 24 vac and only makes a connection for the rest of the unit. It also does not matter which wire you hook to which terminal. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Bryant Heating & Cooling
Goodman GPM075-3 air conditioning connections
your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Dec 11, 2009 | Goodman Heating & Cooling
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Remote Thermostat Control hookup for AZ28E15DABM1
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Jun 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
246 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
