Question about Philips DVD793CH Multi-disc DVD Player
Tray won't open
I am trying to fix a DVD player. My problem is the tray won't slide open
  • Anonymous Apr 11, 2008
    i have a philips dvdr3305 the tray wont open and the message blocked comes up, there is a dvd in the drive and it plays fine but i cannot get it out
  • 91 Answers
There is probably something stuck in there like another cd that is causing it not to open
Posted on Aug 09, 2007
SOURCE:
Dvd door won t open
Remove the unit and open it up to remove disk and examine the tray drive.
Jun 19, 2017 | Curtis Audio Players & Recorders
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
Samsung v8500 dvd stuck
i can understand is this trays is stuck. see the steps and fix it.God bless you.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 03, 2012 | Samsung DVD-V8500 DVD Player/VCR
CD cannot load, will not eject, had to wind down transport manually to get CD out
see this steps and fix it. God bless you
Service a DVD player disc tray:
Oct 02, 2012 | Televison & Video
Monitor doesnt want to open
SEE THIS CAUSES AND FIX IT. God bless you
Oct 01, 2012 | Dual XDVDN9131 Navigation system with DVD...
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
Philips DVD793CH Multi-disc DVD Player Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
