Question about Sub-Zero Refrigerators
Drip Pan Placement
I took out the drip pan to clean it and am having difficulty putting it back in. Does it just sit under there or are there supports I have to put the pan on. Thank you.
  • Sub-Zero Master
  • 4,655 Answers
Go to page 75 in the service manual where it explains the drip pan for different models. Click HERE I will be here should you have questions, Thanks Sea Breeze
Posted on May 03, 2013
Testimonial: "Thanks for trying but the link does not work for me."
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
hotuna
  • 288 Answers
SOURCE: How do I empty the Drip Pan
Remove the grill underneath the doors. A flashlight helps, look for a plastic pan, it should just lift out. Some of the older models the pan is bolted down. If you still cant find it, slide the refer out and take the panel off the back, some are easier this way.
Posted on Dec 26, 2007
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
I have the qbbq2003 Thane Gas Grill - brand new - finally used it today....how the heck do you remove the grates and drip pan for cleaning? Thank you
You just pull upward frpom the outer edges on the grates and they pop off, then remove the drip pan and clean and put back or use aluminum foil instead of buying the new drip pans and shape it to the bottom under the flame unit of each side and replace the grate over top.
Mar 12, 2011 | Garden
Bad odor coming from drip pan when compressor kicks own[when dry]
I just had the same problem with my kenmore side by side. I have been noticing a nasty smell for the last couple weeks when the fan comes on. My husband just took the whole back of the refrigerator apart and put a flashlight in there. We could see the drip-pan and it was filled with stinky black mold!! It was very hard to remove, but he managed to get it out by taking the lower front (where the filter goes) apart and then he was able to slide out the drip pan and clean it out! Problem solved.....but Kenmore should really make the drip pan more accessable!
Apr 12, 2009 | Frigidaire FRS26ZSG
Fan blows out a smell from underneath fridge could it be leaking gas.
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Jul 02, 2006 | Whirlpool GD2SHGX Refrigerator
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
82 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
