Question about Saws
10" Table Saw
Motor stopped working. When I turn it on, the motor hums but the belt does not turn. Could the problem be the Starting Capacitor?
    New Friend:
Assuming the motor shaft is not frozen and the rotor turns freely by hand
All single phase induction (No brushes) motors require energizing a "starting" winding for a second or so to get the thing turning.
Once the armature in turning the "run" windings take over and the start winding is turned off. If power is left on more than a few seconds without the motor starting, the starting winding will be permanently damaged. It can tolerate power for only a few seconds.
The momentary connection to the start circuit is controlled by any of several different methods. The most common system is a switch located at the opposite end of the motor from the output shaft. The switch is in the end cap and there is a flyweight on the armature that opens the switch when the motor gets up to speed. If the switch fails to make contact when stopped the motor won't turn. The contacts can be worn to the point of not contacting or it may have sawdust or other matter between the contacts. Whatever the reason the contact is not making connection to the start winding.
Another method use is an "Inrush" relay. This may be located in the motor or anywhere else like the manual switch box or another box exclusively for the relay. Radial are saws frequently use this system. When the motor is powered up the current is several times the current that it takes to keep it running. This high current (inrush) is detected by the relay and snaps closed until the current falls to the lower running condition. In this design the relay is open at rest and closes for a small amount of time at power up.. In the first design the contact is closed anytime the motor is at rest and opens when up to speed.
Look for a fault in these areas.
There are many other ways to start single phase induction motors, but these are by far the most common.
Posted on May 12, 2013
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
rowdy45176
  • 2176 Answers
SOURCE: Failed electric motor on 10" Craftsman Table Saw
by seized is it burnt up or are the bearings just bad, the bearings are minimal but the field/armature would be more. Give me the model number and I will try and find a breakdown and let me know what we are looking for and I will try and help.
Posted on Oct 01, 2009
Testimonial: "Thanks Rowdy, The motor model is RM871. The table saw is 137.248481. It actually hasn't seized, it still turns very slowly, but makes a terrible noise"
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
  • 5 Answers
SOURCE: I have a 10' Craftsman
If this is anything like my table saw, you shouldn't need to remove the motor, just lower the blade all the way, reach in from the back and place the belt over the pulleys while holding the motor all the way up. If the belt is too short, it might be the wrong one. They shipped me the wrong one twice, I finally went out and purchased a universal belt (constructed kind of like a bicycle chain) from a local woodworking supply shop. Its been working great for 2 years.
Posted on Jun 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
New table saw motor very weak and has problem kicking on
Is there an external phase shift capacitor for the motor? A defective phase shift capacitor can cause no or slow motor rotation and reduced motor power.
Nov 04, 2012 | Craftsman Saws
I have a Sears craftsman radial arm saw ( model # 113.197251) and the motor won't run. I replaced the capacitor and the motor just hums when you turn it on.
did you recently rewire this motor? If so recheck the wiring. If not sounds like you have a problem with the starter windings or switch in the motor itself.
Apr 21, 2011 | Craftsman 10" Table Saw
When I turn on the table saw, I can hear it humming as if the motor is hung up, but the blade does not move. With the power off, the blade turns freely. Also, I removed the belt and it makes the same...
With the blade and nut off the arbor, turn the motor on and VERY CAREFULLY turn or bump the arbor in the direction it is supposed to turn. If the motor spins up to speed you have a bad start capacitor. I have never been able to find start capacitors for Craftsman motors as a seperate part so you may have to replace the whole motor. Check with any local electrician shops first as they may have the capacitor you need.
Apr 13, 2011 | Craftsman 10" Table Saw
My table saw will not start. the power source is good.
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Mar 11, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
Table saw stopped when cutting a dense piece of wood. Now just hums when turn it on. Not locked up, the pully will move by hand. Do you think replacing the capacitor will work. No restart button. ...
One thing you might try is to raise blade to highest setting possible and spin blade as rapidly as you can by hand and turn on while blade is still moving. see If motor will go ahead and come up to speed or try to I would replace start capactor. Also check brushes and make sure motor is clean and free from saw dust. Lube motor if equipped with oil ports. I would just use 3-4 drops and wipe off excess. Blow out with compressed air and also make sure belt is not to tight. I hopes this helps you, Thanks
Nov 17, 2010 | Craftsman 10" Table Saw
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
Apr 11, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Table saw capacitor heats up and explodes.
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Mar 11, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
