Question about Jensen DV2007 AM/FM/CD/DVD
Won't play DVD
I push thee mode button to select DVD but that option will not come up. All I get is AV1 AV2 and tuner. I put a DVD in and it say "reading" for a while then "ERROR" comes across the screen and it switched to the radio station.
4 Suggested Answers
SOURCE: Jensen VM9132 07' model
At audiovox.com has some upgrade files for the jensen vm9312 that is supposed to fix this problem. First you have to find the vm9312 and then click on software updates. Audiovox makes Jensen products i believe.
Posted on Jun 26, 2007
gopakumarg43
  • 75591 Answers
SOURCE: My in dash touch screen
Hello
There are two main reasons for this fault. The first one is confused system control section. The second one is weak Laser Pickup Unit Assembly.
Just reset the system first, to rectify if there is any system confution occured. To reset use the tip of a ball point pen to press the reset button hole, can be located at the front right corner of the player. After system reset, the unit will return to its factory default settings. If the reset is done while a DVD is playing the Dvd resumes play once the reset is complete.
Check out if it helps you or not. If not, put a cleaning disc, and play it two or more times. If there is any dust accumulation on the lens of the Laser Picup Unit, this will rectify the probelm.
If this also not rectifies the problem, the Laser Pickup Unit is defective, and needs replacent. Replace it with samy type and number. OK.
Posted on Jan 28, 2011
  • 17328 Answers
SOURCE: After pushing reset button, system won't do anything. Troubleshooting guide said to push reset in when the "mode sel" button didn't work.
Unplug it from the power.. Wait 5 minutes and plug it back in
Posted on Aug 06, 2012
Can only get av1 and av2 when trying to tune lg v271 video recoder
What kind of wire are you connecting to the antenna jack> Cable or antenna? When you do a tuner setup you have to select which one you will use before doing a channel scan
Aug 22, 2016 | LG V271 DVD Player/VCR
I don't know what channel to go to to be able to play my dvd player
where did you hooked up the connector wire coming from the dvd player, in the component input or at the RF jack of the tuner of the tv?. if you plug at the component input of the tv you will select AV1 or AV2 etc. in the settings. but if you hooked up into the RF jack you can select channel 3 in the tv but at this time you need to have manual tuned in the tv to get the signal coming from the dvd player or xbox.
Oct 13, 2012 | Emerson LC320EM9 32 in. LCD HDTV
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
How do you access the video mode in order to watch a movie on a dvd play or play a video game?
Hi, usually the function button on the remote control to select the input mode / source is a circle or a square with an arrow pointing into it (see below).
b74fea7.jpg Each time you press this, the next available source is selected in a set order, e.g. TV / AV1 / AV2 / HDMI / PC
If using a SCART interface for your DVD player, the TV should automatically switch to the DVD source when you activate the DVD player (take it out of standby).
Nov 26, 2009 | Sylvania Televison & Video
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
TV MODE SELECTION
Look on the back of the unit. On the right hand side will be a removable panel. Inside the panel is a recessed area where the TV Tuner module is mounted. It plugs into a small D connector on the left side of that recessed area. If there is no tuner module mounted in the recessed area, you will not be allowed to select the TV options in any of the menus.
jryduke
Sep 26, 2007 | Philips 17MD255V Combo
Jensen DV2007 AM/FM/CD/DVD Logo
23 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
