Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Low water pressure from my GE water dispenser
The water pressure from my GE Profile fridge (PSS26MSWA SS) is very low. I have verified that the water pressure up to the back of the fridge is fine. I assume that somewhere between the inlet point at the back of the fridge and the water dispenser there is atleast one valve. Do you know how many and where they are located?
  • GE Master
  • 4,655 Answers
Low water pressure from my GE water dispenser - 9986decf-c8b5-4d2a-b7a3-429192b784d0.jpg
This is a link to a photo breakdown of the back of your refrigerator=> HERE Location 800 in that photo is the WR57X10070 Water Inlet Valve The problem you are having is possibly the=> WR57X10070 Dual Water Control Valve is not opening completely. I am adding a video so watch the video and I believe it will make this easier to understand what is happening. I am here should you have questions Thanks Sea Breeze
Posted on May 02, 2013
mikedurland
  • 481 Answers
SOURCE: low flow on ge profile side by side water dispenser
  • the water filter may be clogged (if equipped)
  • or it could be the screen in the water valve clogged a little.
  • or the water supply line could be clogged if it has a needle piercing water valve.
Posted on Jul 04, 2008
  • 531 Answers
SOURCE: location of ge profile water inlet valve
may be to much water trap door open light on door (ajar)
Posted on Apr 01, 2009
  • 101 Answers
SOURCE: GE Refrigerator Model # gsh25jstc
check pressure to refridge,or check for frozen water tank in bottom of fresh food behind bins
Posted on Sep 10, 2010
  • 14 Answers
SOURCE: PSS26MSWA SS - GE Fridge: water dispenser not working
this is a common problem with GE refrigerators. The water line freezes. It is a cheap and easy ($30) fix that takes about 15 minutes. I found a ton of people having this issue so I did a blog post with the symptoms and part to order. Read more about it here.
Posted on Dec 13, 2010
machinetech7
  • 1344 Answers
SOURCE: Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on May 23, 2012
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
try holding the water disp for 5-8 mins to fill the water tank
May 26, 2008 | GE Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
171 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
