Question about Olympus Cameras
Olympus SP-720UZ isn't starting
My Olympus SP-720UZ isn't starting. When I turn it on it shows the options of the selected program and then the screen turns black and it doesn't do anything else. I have to take the battery out to turn it off. What could it be?
  • 3 Answers
SOURCE: BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Posted on Feb 16, 2008
  • 919 Answers
SOURCE: Broken Zoom on Olympus sp-510
Unfortunately this is a repair issue with the camera. You may want to call Olympus Customer Service to discuss their repair policy and procedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Jan 12, 2009
  • 919 Answers
SOURCE: Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Posted on Feb 11, 2009
  • 6 Answers
SOURCE: Zoom Error on Olympus SP-500UZ
I have this exact same camera and I had the exact same error. Since it was no longer under warranty, I decided to see what I could do myself. The zoom tube has a ring surrounding it and on the bottom of the ring there is a tiny Phillips head screw. I removed the screw and loosened and jiggled the ring a little bit. I then turned on the camera and it worked. I replaced the screw and it still worked. I don't know if I was just lucky or what. I would not recommend trying this if the camera is still under warranty. I figured I had nothing to loose.
Posted on Feb 23, 2010
taran_2005
  • 10515 Answers
SOURCE: my FE -340 Olympus camera
This is a common problem. There is a fault within the lens mechanism. The lens error is common for cameras with telescoping lenses.
  • You can help the motor by connecting the AV cable --- this keeps the LCD off and not draw power away from the motor.
  • Remove the batteries and insert freshly charged batteries.
Few more tricks that you could use :-
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #5a: If you actually do notice sand particles stuck in the gaps around the lens barrel, and blowing air does not help to dislodge them, consider using a thin piece of paper or a sewing needle to help dislodge them. Pay particular care not to scratch your lens barrel with the needle. Also, I do not recommend probing too deeply around the lens barrel with the paper (don't go more than a 1 cm or 1/2 in) . Particularly I do not recommend probing deeply around the most outer (largest) lens barrel gap, as you may dislodge the lens barrel dust gasket that's located just inside of that gap.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some obvious potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #6a: This is a variation of Fix #6, and should be tried if the lens barrels appears straight (not crooked). In other words, try this if there's no obvious mechanical damage to the lens barrels that's causing the problem. With the lens pointed down, try "gently" tapping around the lens barrels with a small item such as a pencil or a teaspoon. The idea is to try to dislodge any sand particles that may be jamming the lens barrel stuck. Simultaneously try turning the camera on and off as you're doing this.
Fix #7: The most extreme of the fixes. You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods (see the polls in the right column). HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
More tricks :-
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
Unfortunately, there is no one good trick. This is a common problem and you could try to use any of the above tricks that you could find it comfortable to use.
The best advise would be to contact the manufacturer and get the camera replaced/repaired if under warranty.If out of warranty and the above tricks would not work, repair is usually not advisable as the cost of repair would be high as compared to the cost of the camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 18, 2011
Why is flash not working
That is going to have to be sent to a repair technician
Aug 21, 2014 | Olympus Sp-720Uz Digital Ultra Zoom Camera...
Olympus SP-720UZ screen turns on but remains black
Sounds like a hardware problem... You may have to take the camera to a dealer and have them check it out. However, try this first:
Leave the card out for a while, and recharge it. Then reset the camera to factory defaults is you can (check manual).
You may also want to check with the Olympus web site to see if you have the latest firmware update to your camera model. You could try and download latest version and install it.
Hope any of this is to some help... :)
Mar 31, 2014 | Olympus SP-720UZ Black Digital Camera...
White line on viewing screen
If the line is also on your photos it is a bad censor assembly, if the line is just on the LCD than the LCD is faulty. Either way you are looking at a trip to the repair shop.
Jan 23, 2013 | Olympus SP-720UZ Black Digital Camera...
How do I get my sp-720uz off japenese
Press the MENU button, use cursor-left then cursor-up/down to select the second wrench icon, press the OK button, use cursor-up/down to select the talking head icon, then select English and press OK.
Dec 22, 2012 | Olympus SP-720UZ Black Digital Camera...
How do i get the viewfinder to show fullscreen. At the moment there are 2 black strips down each side in "iauto" mode. When i first had the camera it was fullscreen. Thank you.
The LCD screen on the Olympus SP-800uz camera is widescreen (16:9).
If you set the camera to take pictures in (4:3) ratio you het the black sides.
Solution:
Select a Widescreen Image Size (see the manual page 30) by selecting one of
the available Image Size settings 16:9 (L) (4288×2416) or 16:9 (S) (1920×1080).
Jun 12, 2011 | Olympus SP800UZ Digital Camera
Just got olympus sp-800uz but get 2 black lines down side screen can i make it full screen
Are you talking about the camera's LED screen, or your computer monitor screen?
Anyway, the Olympus SP-800uz camera has 4:3 image sizes and widescreen 16:9.
Just set your camera to the size you need to get your images shown fullscreen.
An alternative is to use a graphic (or tool) program that is able to crop your images.
May 17, 2011 | Olympus SP800UZ Digital Camera
Jan 02, 2009 | Olympus SP-510 UZ Digital Camera
I have a problem with my Olympus SP- 510 UZ digital camera: Although it perfectly displays pictures taken recently, the screen remains all black when I intend to take pictures. It does take pictures...
Sounds like a repair issue with the image processing chip in the camera. You may want to call Olympus Customer Service to discuss repair options and pricing. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 12, 2008 | Olympus SP-510 UZ Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
