Question about Cell Phones
Monsuno secret codes - Cell Phones
Leapsterworld secret codes
looking for creature create to enter secret code
Jul 26, 2014 | Leapster Junie B Jones Top Secret Personal...
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
Jan 27, 2014 | Sharp LC52SB57UN LCD TV
Je veux le code de formatage de lg kc910
LG Secret Unlock code LG Cell Phones Blog
Here is a method to unlock the LG Secret easily and safely. LG Phone Problem and solution
1. insert original sim card and turn your LG Secret on. LG-Secret info
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
5. The LG Secret will then reboot and the unlock is complete.
Oct 05, 2012 | LG KC910 Renoir Cell Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
Increasing volume in samsung s3310i (secret codes)????
sorry there is no secret code for same
Dec 18, 2010 | Cell Phones
I have to remove or Reset my SECRET or SECURITY Codes.
If you dont know what the code is, you have to flash the phone to get rid of the password. You have to know the password.
May 21, 2009 | Nokia 6120 Cell Phone
Mujhe n 72 k pure secret code chahiye please koi meri help kare meri email id hai. afzal.niky@yahoo.in
secret code is very risky.to get secret code you have to paid.i have all secret code of nokia also have the unclok code.
Mar 21, 2009 | Nokia N72 Cellular Phone
Cell Phones Logo
248 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
