Question about Samsung Televison & Video
Turn off beeping sound in menu roaming - Samsung Televison & Video
How do I turn off roam on a zte lever
Go to menu - settings - Connection Settings - data roaming then turn it off.
May 28, 2015 | ZTE Cell Phones
Beeping at odd hours
It is probably either going in and out of roaming or loosing and regaing wifi anywhoooo to fix go to menu then settings and then sounds to turn off wifi alert by putting in airplane mode or also u can turn off roaming. in airplane mode u wont get any noise out of phone , just vibrate so u will have to turn it off to hear calls and alerts
Jul 09, 2012 | Cell Phones
How to turn digital roaming off?
  1. On the Home screen, click the Manage Connections icon.
  2. Click Mobile Network Options.
  3. Perform one of the following actions:
    • To turn on or turn off data service, change the Data Services field.
    • To turn on or turn off data service when roaming, change the While Roaming field.
    • To receive a prompt when roaming that allows you to turn on or turn off data service, change the While Roaming field to Prompt.
  4. Press the Menu key.
  5. Click Save.
Apr 20, 2012 | Samsung Cell Phones
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
My camera makes a beeping noise EVERY time I push a button on it! It's really annoying! How do I turn the beeping noise off???
Tap MENU to bring up the menu screen. Tap the wrench tab to access the Setup menu. Scroll down if needed, and select "Sound Settings." Turn off the "Button Sound" and, if desired, the "Shutter Sound."
This is described in the "Sound Settings" subsection of the "Setup Menu" section of the manual (page 148 in my copy).
Apr 13, 2011 | Nikon Coolpix S4000 Digital Camera
Where can I get a description of what the lg icons are other than what is on the phone? Eg.What does ring and speaker mean? What does one beep and one beep &speaker mean? Roaming icon means what?...
Depends on what model it is BUT generally....
E911 is emergency calls only, meaning no service.
Ring and speaker is audible only
Beep and speaker is vibe and sound
roaming means you are on another carrier's network, other charges may apply depending on your plan.
1X is comparable to dial-up speed. If your in high speed area, you will see EV or 3G
Location is your GPS function on/off
Mar 28, 2011 | Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
Phone keeps beeping when your on the phone, and the id caller dosent show whos calling given to me no instructions
In your phone settings or call settings you should see one labeled " minute beep". Turn this off. It sounds like the phone is beeping to let you know each time 1 minute had passed. (Very useful for roaming or international calls.)
Nov 20, 2009 | Cell Phones
Weak roaming signal with Sprint Katana 2 cellphone
Call sprint and ask them to flag you for a PRL update. Then dial *2 and it will automatically update.
I checked in the Katana II menu and there is no option to update the PRL
Feb 03, 2009 | Samsung Instinct Cell Phone
Sound problem
All you can do is a battery reset. Important thing for battery reset is to always make sure unit is on. Remove the battery. Wait 10 sec and then put it back in. Other then that check your warranty status.
Oct 16, 2007 | Motorola Mobility Q Smartphone
Televison & Video Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
