Question about Garden
Troy built primer but has factory hole in it..WHY? it wont run unless i plug that hole with my fingertip!
Why is this hole there?
  • 15,639 Answers
What is the model number?
Posted on May 06, 2013
On our Troy built we can't start it unless we use jumper cables to touch battery terminal and then the starter
check switch for corrosion make sure all post male and the female plug are clean. Check power to switch with 12 volt test light if you have power to switch check your soilinoid there is one wire that activates your selenoid to send power to starer. .i would guess bad selenoid.
Apr 05, 2017 | Troy Garden
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
What caused Troy built Tractor (pony) stopped running sudden
Replace HT leads with silicone ones, u shud not get any shock from old ones un less they are breaking down,unless they are leaking , u shud now get a big blue spark if not then also replace coil hope this helps
Apr 26, 2014 | Troy Garden
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I can start it, but it shuts down after a 10 seconds
The model number for your post is for the blower attachment. Can you pass the model number of the upper assembly please so we can better help you. Thanks
Kelly (cont below)
I am going to go out on a limb here.. Most of these troy-built trimmers use this carb with primer bulb.
PN 753-1225
http://www.ereplacementparts.com/carburetor-with-primer-p-283336.html
What usually happens to them is the primer bulb on the bottom of the carb gets a pin-hole in it and then air is drawn into the carb vs fuel from the tank.
You can try to get just a primer bulb at your local lawn mower parts supply. You may just have to bite the bullet and replace the whole carb.
Apr 19, 2010 | Troy -Bilt String Trimmer/Blower...
Mower wont stay run n unless i hold primer in
If it is a float bowl carburetor may have a jet clogged or the primer bulb could have a hole in it. If it is a diaphragm type carburetor, the diaphragm may be stiff and needs replacing. Check it out.
Good day.
Nov 07, 2009 | Toro Garden
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
Trimmer won't run.
Sounds like there may be some blockage in the fuel line or a hole in the primer bulb. Take it to a pro and for about 40 bucks let them get the gas on their clothes.
Jul 05, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
