Sony Ericsson T303 Mobile Phone (Shadow Black) Logo
Tom Ward Posted on Mar 15, 2009
Unable to turn on and showing red light
Basically, my t303 phone ran out of battery one day and i went to plug it into the charger to charge it up and on the power button the light just glows red and doesnt want to charge up. when i try to turn my phone on afterwards or at all , it is dead and nothing happenens, even when i try pressing all the buttons, i had 2 of these phones my last one did it but it was covered so i got a replacement, this one has done the same but my insurance has ran out =/ help??
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
573
Points
5
The same happened to me the battery has had it get a new battery and it should work
My phone SE T303 ran out of battery so i plugged it in to charge, the red light came on. When I came to turn the phone on it didn't work. so i plugged in the charger without the battery inside, then put...
short answer is your battery is dead and needs to be replaced. It is hoped you didn't short out the charging port within the phone itself... It is doubtful but can happen..
K850i red light turn on when charger or usb cable plug in & the phone does't start
I just bought a T303 Sony Ericsson I pluged it in to recharge it and a red light come on but no light come on the screen when Iunplug it from the charger.
My t303 wont turn on when its on charge the red
check your power switch bottonm or change your battery...
if not happen. .i think the program of your mobile is need to repair or need reprogram
tnx
57helpful
2answers
When charging the red light comes on but won't turn on
This happenned to me too, here's what I did:
- plugged in the charger WITHOUT the battery inside,
- then put in the battery (while still plugged in).
- The phone came back to life and works fine now.
Hope this helps.
11helpful
3answers
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
1helpful
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
9helpful
11answers
My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Nov 06, 2007 • Cell Phones
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
