Question about Biostar Computers & Internet
Biostar error code c5
I built a new machine yesterday with a Biostar MB, installed Win 7 and Suse Linux. It worked ok for a while but now displays C5 on the motherboard. If I turn off the power supply, wait a minute and turn it on, all is fine.
sandrew
  • 2961 Answers
SOURCE: Is there a power button cable connection adapter for IBM P4 motherboard to Biostar mother board?
if you mean that the power connector is a 3 pin socket connection and the pins on the motherboard are not in line and the middle connector hole is in the way, simply snip with scissors the end connector hole and seperate so you have a 2 pin and a 1 pin and just connect the 2 pin and use as a single connector because you wont need it and connect the 1 pin that you cut away to the other terminal
Posted on Jun 04, 2007
SOURCE: no video after power up biostar t series MOBO w/ Semprem cpu
i was installed xp sp2 but vga driver & multimidia driver not installed
Posted on May 25, 2009
  • 788 Answers
SOURCE: can biostar k8m800 m7a 754 run windows 7
The processor will run windows 7 but may not be very fast.
Look for the correct driver for the m/b at BIOSTAR.com
Posted on Dec 27, 2009
  • 45 Answers
SOURCE: need 64 bit usb drivers for my motherboard - a Biostar G41-m7
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421
try this one
Posted on Mar 23, 2010
  • 4 Answers
SOURCE: No audio from Biostar g31-m7 te motherboard
To whom it may concern
1.download the audio driver for the appropriate model number of the mother board and install it.
2.If it says "there is other device with pci device"it means the bios is recognizing a pci sound card.if you did install a sound card load the appropriate driver cd that came with your sound card.if this does'nt work try step 3.
3.if no sound card was installed then then uninstall the driver for the pci device or uninstall both drivers and try loading the appropriate driver from the motherboard manufacturer website if non of these steps work.
4.Search for the appropriate motherboard bios update then try loading appropriate audio drivers.
Posted on Sep 20, 2012
My Motherboard is Bioster but doesn't windows 7 installation process. so solution
Windows 7 can, in many cases, work on older motherboards using generic drivers built into the OS. Some components may not work, or may work using VISTA drivers downloaded from the MFGR website. You will need to provide the BIOSTAR MB Model number for me to assist you more than this.,
Sep 14, 2013 | Biostar Computers & Internet
GPU hardware not recognised
Hello the homepage is here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#dl
Try to download a manual if you don`t have it.
If any drivers for the mainboard is missing install them.
Install the newest NVIDIA graphic driver from here:
http://www.geforce.com/drivers/results/49949
This is the 64 bit version.
Check also if the graphic card is properly insertet
in the slot on the mainboard.
And the graphic card has to support PCI-E X16
This graphic card needs extenal power
from the power supply to work
the power supply has a wire with pci-e stamped in did you connect this ???.
Try to disable the onboard graphic in the device manager.
Good luck
Nov 15, 2012 | Biostar TZ75B ATX Intel Motherboard with...
Need linux drivers biostar a780l3b
Hello here is the homepage for the mainboard:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=536#dl
But here is only windows drivers.
Here is a page with linux drivers:
http://www.linux-drivers.org/
Not all mainboards is supported.
Good luck
Nov 08, 2012 | Computers & Internet
I need vga driver of p4m800 pro-m7
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=94#dl
But the driver for win 7 is not there.
It will not help to download the xp driver
My advise is to buy a graphic card that supports win 7
The mainboard have an AGP 8X Slot for extenal graphic card
If you are in doubt adding a graphic card
let a expert do it for you.
Good luck
Oct 30, 2012 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Could not found biostar g41d3c driver for win 7 32-bit os
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=518&tab=3
Mar 21, 2012 | Biostar G41D3C LGA 775 Intel G41 Micro ATX...
TA790XE Ver 6.0 Have been running a 9650+ for a couple years. bought a 1090T and installed it. Bios is the newest and recognizes the CPU. Win 7 boots to the point the desktop starts and then goes to a...
Hi, here you can see a list of cpu that your mainboard supports:
http://www.biostar.com.tw/app/en/mb/cpu_support.php?S_ID=417
You maybe have to download a manual.
It will show you how to unlock all the cores at the cpu.
That means you have to enter the bios to make a setting
so the bios can work with the new cpu.
Aug 31, 2011 | Biostar TA790XE 6x AMD 790X Socket AM2 MB...
Where can i find a download for g3i-m7te because i accidentally deleted it
http://www.biostar.com.tw/app/en/support/download.php
I don't know what version of the G31-M7TE you have, they list three at this link, but hopefully this helps you. I don't see anything for Win 7 but They do have Vista and earlier.
Mar 16, 2011 | Biostar G31-M7 TE Motherboard
Motherboard doesn´t work
You also have a manual for the Biostar? Find the serial No# printed on the Mb. Usaully found on a white sticker found on the serial port. With the serial No# in hand look up your board on Biostar's web site. Download the manual. You will find what CPU's your MB can take.
Dec 04, 2007 | Biostar P4M800-M7A Motherboard
Computers & Internet Logo
22 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
