Question about Larin Academy Sports Rear Cargo Carrier
Assembly guide for larin rear cargo carrier model # CC-500
1) do NOT tighten nuts as you assemble. Loosely finger tighten to keep bolts in place during assembly.
Tools: adjustable wrench, ratchet, quick release clamp, linesman pliers.
2) think about a zipper closure, start at one extreme end point and work top side bolt hole, bottom side bolt hole, next bottom bolt hole, middle bottom bolt hole, etc. I suspect the factory measurements are slightly off, so the holes are not aligned perfectly. Using the clamp to slightly bend the metal helps align the first outer bolt hole and gets the rest of the holes lined up.
3) can be done as a 1 person job, I suggest having an extra set of hands for holding carriage bolt heads still while tightening. Also for lifting, extra set of eyes to ensure cage parts are aligned correctly, and helping you keep your patience.
4) place entire assembly on the trailer hitch, test you rear gate/ door movement, and spacing in the garage.
5) if you decide you would like to keep the device, go ahead and finish tightening the bolts with wrenches, opening and closing the cage as needed, to keep carriage bolts in place. (This is where extra set of hands will help out again.)
i just finished assembling this myself and had to draw on 20 yeas of experience with assembling poorly aligned objects. I had to walk away once or twice to calm down before I stripped or bent one of the bolts.
I could not not find any helpful hints on any sites or YouTube channels. I hope you find this helpful with your assembly project.
Posted on Apr 06, 2014
How do I repair a stuck shut rear cargo door on a 2003 Suzuki Vitara?
stuck has 3 meanings, (lock dead, 2 ways, or not and is really stuck)
ok so the fob is dead? just on this door?
and cant here the solenoid click>? at that cargo hatch?
did you check the child lock outs switches.??????????
lost the operators guide. on that.>?
say so and can post the page. you lost.
May 18, 2016 | 2003 Suzuki Vitara
I have broken the rear wheel drive shaft on my Jonway Master 250. How do I replace this and is there a free diagram of the complete assembly available?
Firstly,you seem to have a good grounding in basic mechanic's ,so be brave and just "do it! You certainly cant make it any worse,can you? ALL THE BEST!!
Sep 30, 2014 | 2010 Jonway GTS 500
How to install rear struts on a 1999 llexus
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Print
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    Rear tire and wheel assembly Rear stabilizer link Rear axle shaft nut Rear disc brake caliper and disc Speed sensor Parking brake assembly at the wheel hub No. 1 and 2 upper control arm assembly No. 1 and 2 rear suspension arm assembly Toe control link Rear axle from hub assembly using a plastic hammer No. 2 rear wheel bearing dust deflector using a screwdriver 4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
  1. Install or connect the following:
    Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm) No. 2 rear wheel bearing dust deflector using a screwdriver Rear axle into hub assembly No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt. No. 1 and 2 rear suspension arm assembly. Temporarily tighten. Toe control link. Torque new nut to 52 ft. lbs. (70 Nm). Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm). Parking brake assembly at the wheel hub Rear speed sensor Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer. Rear brake disc and disc brake caliper
  2. Adjust the parking brake.
  3. Stabilize the suspension as follows :
    1. Install the wheel(s).
    2. Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
    3. Raise the vehicle.
    4. Remove the wheel.
    5. Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
  4. Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
  5. Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
  6. Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
    NOTE If it is necessary to replace the hub or bearing, replace the components as an assembly.
    Rear tire and wheel assembly If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way. Brake rotor or drum 4 bolts and pull off the rear axle hub O-ring
To install:
    Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm) Rotor or drum Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm) Wheel
  2. If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
    Negative battery cable Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Cotter pin, lock cap and the nut holding the halfshaft to the rear axle Suspension member brace by removing the 2 bolts Halfshaft bolts and washers Halfshaft from the vehicle Strut rod
  4. Place matchmarks on the adjusting cam and body for the No. 1 control arm.
  5. Remove or disconnect the following:
    Nut and adjusting cam Nut on the axle carrier side of the No. 1 lower control arm Separate the control arm from the axle carrier No. 1 lower control arm Stabilizer bar link from the No. 2 lower control arm.
  6. Place matchmarks on the adjusting cam and body.
  7. Remove or disconnect the following:
    Nut and adjusting cam from the No. 2 lower control arm Nut and bolt holding the No. 2 lower control arm to the axle carrier No. 2 control arm from the vehicle Nut and bolt on the lower side of the strut assembly 2 upper control arm set nuts and bolts Axle carrier with the upper control arm
  8. Secure the axle carrier in a vise.
  9. Remove or disconnect the following:
    Nut holding the upper control arm to the axle carrier and remove the control arm Dust deflector. Use a suitable prytool. Oil seal
    Fig. Removing the oil seal (inner)-LS 430
  10. Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
  11. Remove or disconnect the following:
    Axle hub
    Fig. Removing the axle hub from the axle carrier-LS 430
    Backing plate. Inner race (outside) from the axle hub
    Fig. Removing the inner race (outside) from the axle hub-LS 430
    Oil seal (outer) from the axle
    Fig. Removing the oil seal (outer)-LS 430
    Snapring from inside the axle housing Bearing from the axle housing
To install:
    New bearing to the axle housing Snapring to the axle carrier, using snapring pliers New outer oil seal. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (outer)-LS 430
    Backing plate to the axle housing. Do NOT install the bolts or nuts at this time. Inner race (inside) to the axle housing Axle hub to the axle housing Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm). New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (inner)-LS 430
    New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier. Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm). Axle carrier and upper control arm to the vehicle as an assembly 2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm) Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm). Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm). Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm). Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm) No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm). Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm). Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm). Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm) Parking brake shoes and cable Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm). Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm). Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm). Lock cap and cotter pin Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm). Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm). ABS speed sensor and wiring harness Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm). Rear wheel(s) Negative battery cable
  2. Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
  2. Remove or disconnect the following:
    WARNING Be careful not to damage the boot and ABS sensor
    Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Toe control link Separate upper control arm assembly Shock absorber from axle carrier Suspension arms No 1 and 2 from axle carrier Rear axle from carrier
    Wheel bearing dust deflector 4 bolts and axle & bearing hub assembly
To install:
    4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm) Rear wheel bearing dust deflector Rear drive axle Upper control arm. Temporarily tighten No 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm) Shock absorber. Temporarily tighten Toe control link. Tighten to 37 ft. lbs. (50 Nm) Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm) Height control sensor Parking brake shoes and cable Speed sensor Rear disc brake caliper Fully tighten shock with new nut to 52 ft. lbs. (70 Nm) Rear tire
  2. Inspect and adjust rear wheel alignment
  3. Check ABS speed sensor signal
    Rear wheel Wheel speed sensor Axle halfshaft Brake caliper and rotor Parking brake shoes Parking brake cable No. 1 lower suspension arm bolt No. 2 lower suspension arm bolt Toe control link Upper ball joint Axle carrier from the vehicle
  3. Press the hub out of the wheel bearing, then remove the backing plate.
  4. Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE Use a new toe control link nut for assembly.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Backing plate bolts: 43 ft. lbs. (59 Nm) No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm) No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm) Toe control link nut: 36 ft. lbs. (49 Nm) Upper ball joint nut: 80 ft. lbs. (108 Nm) Brake caliper support bolts: 77 ft. lbs. (104 Nm) Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
    Rear tire and wheel assembly Brake caliper support bracket Brake rotor Skid control sensor wire 4 bolts and rear hub and bearing assembly Skid control sensor
To install:
    NOTE Inspect bearing back lash and hub deviation
    Skid control sensor Rear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm) Skid control sensor wire
    Rear disc Rear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm) Flexible brake hose Rear tire and wheel
  2. inspect and adjust rear wheel alignment
Stabilizer Bar
  1. Remove the rear wheels.
  2. Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
  3. Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
  4. Remove the stabilizer bar.
To install:
  1. Install the stabilizer bar.
  2. Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
  3. Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
  4. Install the rear wheels.
  5. Inspect and adjust rear wheel alignment.
Strut & Coil Spring
    CAUTION Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
    No. 2 luggage compartment trim cover Left and right deck side trim box Rear luggage compartment trim cover Front luggage compartment trim cover Left and right side luggage compartment trim covers Rear wheel Rear wheel fender liner No. 2 differential support protector Rear suspension member brace Rear No. 2 lower control arm Mounting bolts and strut assembly
  3. Secure the strut in a vise.
  4. Compress the coil spring
    Upper strut retaining nut Suspension support Upper insulator Bumper Coil spring Insulator
Dec 26, 2011 | 1999 Lexus ES 300
Electric window feel down broken mechanism
Glass & Regulator
Fig. View of inner door frame and window regulator assembly
  1. Lower the window glass and remove the door panel.
  2. Carefully peel off the door screen so that it can be reused.
  3. Raise the window enough to reach the regulator bolts, hold the glass underneath and unbolt the glass from the regulator.
  4. To remove the glass, raise the glass by hand and tilt it as necessary to remove it from the track.
  5. To remove the regulator, lower the glass carefully to the bottom of the door and remove the bolts to remove the regulator.
  6. Installation is the reverse of removal. Tighten all bolts to 61 inch. lbs. (7 Nm).
Fig. Installing the door glass regulator
Motor
  1. Remove the door panel.
  3. Unbolt the window from the regulator and carefully lower it to the bottom of the door.
  4. Disconnect the wiring and remove the motor mounting bolts.
  5. Remove the 3 guide rail bolts and lower the motor and guide rail assembly out the bottom of the door.
NOTE The upper cable must be below the guide rail mounting bracket.
Showing window regulator motor, or assembly carrier with window regulator, removal/installation
Fig.
NOTE The illustration shows the removal and installation of the window regulator motor/assembly carrier with the window regulator on the rear doors. The procedure for removing and installing on the front doors is the same.
Fig. Slide a hammer shaft between the window guide and the assembly carrier until the end of the hammer shaft presses against the assembly carrier. Remove the screws and take off the window regulator motor
  1. Slide a hammer shaft between the window guide and the assembly carrier until the end of the hammer shaft presses against the assembly carrier.
  2. Remove the screws and take off the window regulator motor.
To install:
  1. The gearing will move when the window regulator motor is removed; it is then no longer centered. The gearing must be aligned when the window regulator motor is installed until the window regulator motor is centered again.
  2. Installation is the reverse of the removal (see illustration).
Motor & Regulator
NOTE The illustrations in the procedure show the replacement of the window regulator motor/carrier assembly with window regulator for rear doors. The procedure for front doors is the same.
  1. Remove the front or rear carrier assembly.
  2. Slide a hammer handle between the window guide and carrier assembly until the hammer handle end presses on the gears of the carrier assembly.
  3. Unfasten the bolts (1) and remove window regulator.
    Fig. Unfasten the bolts (1) and remove window regulator
To install:
NOTE By removing window regulator motor, gearing shifts, it is not centered.
Fig. By removing window regulator motor, gearing shifts, it is not centered
  1. When installing window regulator motor, the gears must be aligned until the window regulator motor is centered again.
  2. Attach and tighten the bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  3. Carrier assembly with window regulator, installing:
    1. For replacement part carrier assemblies, the gearing is secured in place with a cable tie.
      Fig. For replacement part carrier assemblies, the gearing is secured in place with a cable tie (1)
    2. Slide a hammer handle between window guide and SF so far until hammer handle end presses on gears of SF.
  4. Remove the cable tie .
  5. By removing window regulator motor, gearing shifts, it is not centered.
  6. When installing window regulator motor, gears must be aligned until window regulator motor is centered again.
  7. Attach and tighten bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
Hope this helps to solve it.
Dec 14, 2010 | 2002 Volkswagen Jetta TDI
Replace the window regulator on the drivers side
Please don't forget to rate! Thanks!!!
Motor & Regulator
To install:
NOTE:By removing window regulator motor, gearing shifts, it is not centered
    • For replacement part carrier assemblies, the gearing is secured in place with a cable tie.
  • Slide a hammer handle between window guide and SF so far until hammer handle end presses on gears of SF.
  • Remove the cable tie .
  • By removing window regulator motor, gearing shifts, it is not centered.
  • When installing window regulator motor, gears must be aligned until window regulator motor is centered again.
  • Attach and tighten bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  • // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Dec 09, 2010 | 2001 Volkswagen Cabrio
    How to replace rear wheel bearing on 2003 hyandia sonata
    Hub & Bearing Removal & Installation To Remove:
    1. Release parking brake.
    2. Remove rear wheel assembly.
    3. Remove rear wheel speed sensor from carrier.
    4. Dismount brake caliper and support with mechanic's wire.
    5. Remove brake disc.
    6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
    7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
    8. Remove carrier.
    9. Remove stakes and remove flange nut.
    10. Support bearing outer race flange and press rear axle hub out.
    11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
    To Install:
    1. Apply thin coat of grease to bearing contact surface and hub.
    2. Using and appropriate tool, press bearing into hub. CAUTION
      Do not press against outer race of wheel bearing.
    3. Install flange nut and stake nut until it meets concave portion of spindle.
    4. Install carrier.
    5. Use an appropriate tool to press tone wheel.
    6. Install hub/bearing assembly with rounded portion of outer race facing up.
    7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
    8. Measure wheel bearing starting torque with a spring balance or equivalent device.
      • Starting torque should measure 15.9 in lb (1.8 Nm) or less
    9. Install brake disc.
    10. Mount brake caliper.
    11. Install rear wheel speed sensor to carrier.
    12. Install rear wheel assembly.
    Oct 28, 2010 | 2001 Hyundai Sonata
    What do I need to unscrew in the trunk to change the reverse light in my 01 chevy impala
    Tail Lamp Assembly Removal & Installation To Remove:
    1. Open the rear compartment.
    2. If equipped, disconnect the cargo net.
    3. Remove the wingnut and pull back the rear compartment trim panel.
    4. Remove the wingnuts from the tail lamp assembly.
    5. Remove the tail lamp assembly from the rear body panel.
    6. Disconnect the electrical connector from the tail lamp assembly.
    7. Remove the tail lamp socket by turning counterclockwise.
    8. Remove the side marker lamp socket by turning counterclockwise.
    To Install:
    1. Install the side marker lamp socket by turning clockwise.
    2. Install the tail lamp socket by turning clockwise.
    3. Connect the electrical connector to the tail lamp assembly.
    4. Position the tail lamp assembly to the rear body panel.
    5. Install and secure the wingnuts that attach the tail lamp assembly to the body panel.
    6. Position the rear trim panel to the rear compartment. Install and secure the wingnut.
    7. If equipped, connect the cargo net.
    8. Close the rear compartment.
    Oct 18, 2010 | 2001 Chevrolet Impala
    Cargo brake light works but my rear brake lights dont. reverse and turn signals work fine. 04 silverado
    check wiring harness behind light assembly for a loose or broken ground wire. this would not affect the third or "cargo" brake light
    Apr 22, 2010 | 2003 Chevrolet Silverado 1500
    Left rear turn signal bulb is burned out.
    Tail Lamp Assembly
    To Remove:
    1. To Install:
        Please don't forget to rate !!!!!!
      Mar 28, 2009 | 2002 Buick Century
      The cargo door and glass is locked, and the actuator will not unlock.
      how do you removed the interior cover? for the rear door actuator?
      Oct 12, 2008 | 2006 GMC Yukon Xl Denali
      Larin Academy Sports Rear Cargo Carrier Logo
      1,328 people viewed this question
      Top Larin Cycling Experts
      Michial Gueffroy
      John Egan
      John Egan
      Are you a Larin Cycling Expert? Answer questions, earn points and help others
