Hi I have a 24 SE Mynute Vokera boiler I have a three wire cable ( live, neutral and earth) going out to the back where the boiler is but I need to go out every night to turn down the thermostat on the boiler to turn off heat because if i turn of the switch in the house this turns off all power to the boiler which the plumber says is bad for the boiler he said I need a qe1 switch what is this and do I not need more wires going from my house to the garage out the back. Any advice would be great
  • Heating & Co... Master
  • 2,598 Answers
Do you not have a room theromstat to turn down the heating in the house ?
Posted on May 03, 2013
  • Gareth May 03, 2013
    No room thermostat in house
  • 70 Answers
SOURCE: Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Posted on Jan 16, 2009
billyvangogh
  • 108 Answers
SOURCE: how to wire a digital room thermostat
The switched live will be the Live on the original....Live being "Hot" that's the wire you want to switch on and off
Posted on Oct 25, 2009
  • 12 Answers
SOURCE: How to wire tower rs room thermostat to Vokera
if you go on thier web site you can down load a manual
Posted on Nov 01, 2009
SOURCE: I have a vokera mynute 16e boiler and the light is
If this is a newer boiler, if it has a control board with a 24volt output
check to make sure boiler has line voltage to it. No fuse Blown/Breaker
Tripped.
If that is not the problem and power is available it could be the thermostat. If there is a pump involved,make sure it can operate
Posted on Dec 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Three wires not marked for new Thermostat!
You will need to go to the heating system and see what color wires are hooked to that. Typically the black and white wires will be used unless they used another color due to a bad wire. Hook the colored wires to the R or RH terminal on the thermostat and the other wire to the W terminal. You can also try taking the wires you have and one by one twisting them together and have a second person inform you when the heating system turns on. Take those two wires and hook them to the terminals I mentioned above.
Posted on Jan 14, 2010
How to wire wh601 1 gang switch
If it's a one-way switch, there'll be two terminals.
One for constant live cable (e.g. from the fusebox), the other for switched live cable (going to the light bulb). The two neutrals and earths if available should be connected together (neutral to neutral and earth to earth only).
Feb 13, 2015 | Electrical Supplies
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
My vokera mynute 25 ehe boiler was wroking fine until yesterday when my wife turned the selctor to 0, thinking she was turning it off. When i turned the selector back to 1 last night, the boiler wouldnt...
My name is Carla and I work for Vokèra in the marketing department, I am sorry to hear that you are having problems with your Vokèra boiler and I would like to help you get this problem sorted as soon as possible.
Please email me your contact telephone number and I will arrange for a member of our service team to contact you, alternatively you can contact them on the numbers below.
Email: marketing@vokera.co.uk UK: 0844 391 0999 (option 2) ROI: 056 7755055 (option 2)
Aug 02, 2011 | Heating & Cooling
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
