Question about Dometic RM2852 Refrigerator
Rm2852 thermostat Where is the thermostat located at on this model.
    Top Expert:
  • Dometic Master
  • 8,686 Answers
Inside on coilsee inside for instuctions on changing up or down
Posted on Jun 03, 2016
Unit will come on and get cold and shutoff and will not come back on when temp reises
Its hard to say for sure the Model number rm2852 doesn't match any brand I know of.. But as a rule if your Refrigerator runs up to temp then shuts off, but never turns back on when more cooling is needed, it means the thermostat is bad.... sometimes you can tap the thermostat knob with the back of a screwdriver and the refrigerator will start up. I maybe able to give you more detailed info if I knew the bran name.
Mar 07, 2014 | Dometic RM2852 Refrigerator
My Dometic RM2852 regiferator is freezing food and there is no manual temperature control.
I have found that certain types of food will freeze when left against the back wall of the refrigerator, which is where the cold air circulates down from the freezer..moving it away from the back wall can help...
Dec 16, 2012 | Dometic Refrigerators
We have a Domestic Model RM2852 refrigeratro in camper with auto factory preset thermostat. but it freezes the food. What can we do to set temp. down. Product # 921 1460-57. Serial # 319 05815 Thank...
you have 2 choices #1 is replace the thermostat.#2 is check for air leaks around the door seals,if leaking air,compresor will run on overtime...trying to cool the air inside.
Aug 14, 2010 | Dometic RM2852 Refrigerator
The top freezes great, however the bottom will never get below 50
If the top is running super cold and the bottom is luke warm it usually is a sign that your defrost drain is blocked and ice has formed all over your cooling coil path into the fridge section. Thus blocking airflow.
I would use up the food in the fridge now and then turn it off for a couple days to let it defrost manually. If you get a huge flow of water that overflows your fridges catch pan...you probably have that problem.
The answer is to locate and clear out the drain line of all guck using hot water and perhaps an improvised snake of some sort. You might need to remove the inner panel from your freezer to locate the cooling coil drain.
Let me know how it goes ok? Good luck!
May 04, 2010 | Dometic RM2852 Refrigerator
My RM2852 Is Freezing the food in frige section, what might the problem, be? Does this unit have a defrost switch??
Located in the inside in the rear top of the fridge are aluminum fins. on one of the fins near side of fridge there is a folded aluminum sleve that skides up and down on the fin.
this actualy adjusts the temperature of your fridge. slide up or down to adjust fridge cabnit temperature.
Aug 28, 2009 | Dometic RM2852 Refrigerator
RM2852 has never worked on electric.
there a 3 electrical parts
1) the switch
2) the thermostat
3) the heater element
You will need to test for fault , but most likley is the element
Aug 16, 2009 | Dometic RM2193 Compact Refrigerator With...
I have a Dometic model RM2852 it will go to o in the top but
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
appliancepartsse@yahoo.com
Jul 21, 2009 | Dometic RM2852 Refrigerator
Just bought a 1999 camer and we cant get fridge to turn on
If you like I will help you repair your Dometic Model Number RM2852 or click on HERE=> ALL THE ANSWERS FOR DOMETIC CAN BE FOUND BY CLICKING HERE
Thanks, Sea Breeze
Jul 11, 2009 | Dometic RM2852 Refrigerator
Dometic RM2852 Refrigerator Logo
206 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
