Carrier weathetmaker 8000 58wav flashing code 33 then 13. Blower isnt coming on in heat or cool. Capacitor and fuse are good, is it the motor
    New Friend:
  • 28 Answers
The only way to be sure is to contact the manufacturer. Error codes can be different based on manufacturers and models.
Posted on May 02, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier 58MVP; Blower on, no
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Posted on Nov 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Posted on Apr 08, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: Carrier furnace 58gpa075 - CA blower/capacitor issue
the cap is usually next to the contactor on the outside unit and most are dual caos one terminal for fan marked "F" and one marked "H" for hermetic compressor and will have 2 mfd ratings at 370volt or 440 volt a.c. operation
Posted on Sep 26, 2009
  • 19 Answers
SOURCE: Blower motor doesn't start with capacitor installed!
you need a meter that will measure uf (micro farads) it should read within about 10% of the rating 12.5uf otherwise you could charge it with an insulation tester (megger) and short the terminals with an INSULATED screwdriver to see if it discharges.
Posted on Dec 21, 2009
Testimonial: "Thanks for the help. I didn't have the propper equipment but a $7.75 risk was easy to take, so I bought capacitor in a local shop and It worked!"
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Carrier Furnace LED Good, Blower does not kick on
Likely a variable speed blower. Very common to not get 24 to the blower. Carrier is notorious for bad blowers, double check for 240, don't believe it has a separate module, but that's probably all it is. Likely have to replace entire motor. Good Luck
Mar 20, 2017 | Heating & Cooling
Bryant furance cat.# 333BAV048080, with A/C cooling selected, blower motor during high speed operation stopped running, but the outside A/C unit was still running.Check that the motor is free wheeeling....
Hello, sincebthe motor will not run in heating and cooling the first thing to do is check the capacitor, set your meter to ohms and disscharge the capacitor with a screwdriver, if the capacitor is good the meters numbers should ramp up and down, if not the capacitor is bad. To check the motor turn off power to the unit and take you meter and measure from the common wire to each other wire coming from the motor, you should have resistance,if not the motor is bad and must be repalaced. To check the board place one meter lead on the cool/high speed motor tap and the other lead to ground, if therebis no power on a call for cooling the board is bad.
Jul 11, 2011 | Heating & Cooling
I have an 18000BTU unit that has an LED that flashes 5 times and then stops,could you pls advize as to the error code of the LED flashes.
You haven't mentioned the brand name. As the error code changes brand to brand I give some solutions. Check with your unit.
e-5 Outdoor activation of compressor over heat protection-Clean condenser coil and check out door f.motor speed. If less replace capacitor.
e-5. Blower motor lock Rotate manually. If hard to rotate, replace bearings or motor. If easy to rotate, replace capacitor.
Please mention brand name and other full details to get solution quickly. Thanks.
Jan 10, 2011 | Carrier 36KCARMS Air Conditioner
My Carrier 43B00HP - 1 is not blowing cool air. The fan is working but the cool air isnt coming out. If you turn it on and leave it on for awhile it turns off by itself
Please check your compressor whether it takes correct amphs. Due to weak in capacitor and also less rpm of fan motor the compressor gets overheated and it turns the unit off. If capacitor weak change it. If less rpm on fan motor change fan capacitor or fan motor.
Dec 12, 2010 | Carrier Heating & Cooling
Blower motor
fuse under the dash and under the hood but if fuses are good you may just have a bad blower motor check the wires on the blower motor first for connection before replacing
Jan 25, 2009 | 1997 Ford Escort
Blower does not turn on bottom squirrl cage carrier weathermaker ignitor works pilot starts flame comes top fan starts - runs for 3 minutes then bottom squirrl cage does not start up. fuse on board good?...
Sounds like it to me. You might be able to switch the motor speeds by taking the red wire off the heat spot on the board and taking the one that is on the park and switching them. But more then likely the blower is bad replace the capacitor at the same time.
You could take the black wire and switching with red or what ever color is on the heat spot. The black wire is on the cool spot so just switch those two. ken
Dec 09, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000Vs
This is nothing short of a circuit board fan relay of a bad motor.. to find out if the motor is good, unplugg the black & white wire , in which white =ground black=hi-speed 120volts and conect them to power -ground and see if the motor works..if does, then its the fan circuit board if not then its a bad motor...
Jul 18, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
