Question about Dell 1320c Laser Printer
Print on left side of paper lighter than right side
    New Friend:
  • 28 Answers
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
Posted on May 02, 2013
5 Suggested Answers
  • 4 Answers
SOURCE: Dell Color Laser 1320c printer. The left side of
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
Posted on Dec 10, 2010
  • 31 Answers
SOURCE: Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
Posted on Jan 27, 2010
  • 88 Answers
SOURCE: when I try to print, the paper stops moving on the
You have rollers that pull the paper in the printer, it sounds like one of them is dirty. try cleaning the rollers, You may have a broken, just inspect to see. more than likely just needs cleaning.
Posted on Feb 21, 2010
  • 7 Answers
SOURCE: have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Posted on Jun 05, 2012
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
Printing on left side of paper is much lighter than the rest of the paper
Take out the drum unit and remove the shutter. (Temporarily). Then order a new imaging unit
Mar 03, 2011 | Kyocera Copystar CS-1820 Black and White...
Prints lighter on left side of most pages. Even with new toner and fuser and toner darkness turned up to 9 or 10.
This is a bit tricky, but try it
remove the toner cart and lower the top cover about 1/2 way. Look inside and you will see 2 grey rollers hanging from the top on 2 arms. Move the right side arm to the right and grey rollers will fall out (they are as wide as a sheet of paper)
use a light scrubbing with a damp cloth to remove the grey, the rubber should be a tan colour. Dry them off well, insert the left side first (cover in the 1/2 closed position makes moving that right arm easy. install the toner cart again and print a page. It should be nice and dark now, just make sure the rollers are dry when you reinstall them.
Jan 11, 2011 | Office Equipment & Supplies
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Mar 16, 2009 | Nintendo Professor Layton & the Curious...
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
The printer needs servicing , either transfer roller or the laser scanning unit needs servicing to clean dust/humidity.
omnipresent
Nov 04, 2007 | Samsung ML 2010 Laser Printer
Dell 1320c Laser Printer Logo
126 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
