Iburst desktop modem with TL-Mr3420 router
I have an Iburst desktop modem. I want to connect to TL-Mr3420 router to have wi-fi in my house. My PC, ipad and phone connects with router but I get messsage: No Internet connection. What should I try?
  • 899 Answers
SOURCE: No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Posted on Oct 14, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
kakee
  • 1269 Answers
SOURCE: DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Posted on Apr 15, 2009
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
veryfunnyman
SOURCE: router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Posted on Aug 07, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
HOW TO SET UP TL-MR3420 USING GLOBE POSTPAID CONNECTION
follow these steps:
1- connect your pc with router
2- open browser.
3- type the ip address of router : 192.168.0.1
4- press on quick setup.
5- choose the first option 3g/4g
6- press next
7-set location , AT&A , username , password
8- press next
9- finish
make sure your wireless usb was connected with router in the area range of wireless of your isp .
Nov 27, 2013 | TP-LINK TL-MR3420 Wireless Router
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
TL-MR3420
insert your 3G Card adapter to the USB port and thenuse your PC come to http://192.168.1.1 log in to the admin with name admin, password admin .
Open the operating status, it will show being identified, waiting about 20s it will done. else if it can't be recognized. You need to set the BIN file by you self, you can download the file from www.tp-link.com
Then set it step by step as it show
May 02, 2013 | ASI Tp-link Tl-mr3420 300mbps Wireless N...
I csl modem can not be used due to wrong settings
Push and hold the reset button for 30 seconds or so, release. A user manual can be found here: http://www.tp-link.com/us/products/details/?model=TL-MR3420#down
Jan 24, 2013 | TP-LINK TL-MR3420 Wireless Router
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
