Question about Dell 1320c Laser Printer
Left Print Side IS lighter than right - Dell 1320c Laser Printer
  • Dell Master
  • 3,287 Answers
You may be beginning to run low on toner. Many toner manufacturers have users gently shake or tilt the toner cartridge back and forth prior to installing. This is to help break up any settling of toner between the time of manufacturing and installation. If that step was skipped, toner may not have been evenly distributed within the cartridge itself.
Replacing the cartridge (or possibly removing this one and shaking gently and then reinstalling for a little more life) should solve the problem - unless there is another issue. Make sure you read the installation instructions!
Posted on May 02, 2013
Print on left side of paper lighter than right side
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
May 02, 2013 | Dell 1320c Laser Printer
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
Prints lighter on left side of most pages. Even with new toner and fuser and toner darkness turned up to 9 or 10.
This is a bit tricky, but try it
remove the toner cart and lower the top cover about 1/2 way. Look inside and you will see 2 grey rollers hanging from the top on 2 arms. Move the right side arm to the right and grey rollers will fall out (they are as wide as a sheet of paper)
use a light scrubbing with a damp cloth to remove the grey, the rubber should be a tan colour. Dry them off well, insert the left side first (cover in the 1/2 closed position makes moving that right arm easy. install the toner cart again and print a page. It should be nice and dark now, just make sure the rollers are dry when you reinstall them.
Jan 11, 2011 | Office Equipment & Supplies
Dull colors on half the page
I would replace the transfer belt see if that makes a diffrence hope this helps
Nov 20, 2009 | HP Color LaserJet 2600n Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Mar 16, 2009 | Nintendo Professor Layton & the Curious...
Left side of page lighter than the rest, you can't hardly read it
It sounds like the develop blade on your imaging unit needs to be cleaned. If you either clean it or buy a new one. If you are interested in cleaning it yourself I can send you a document on how to do this.
Jun 26, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Printing lighter on left side
Try cleaning the corona wire/ charge roller if this doesn't work replace the image drum
May 16, 2008 | Samsung CLP 300 Laser Printer
The printer needs servicing , either transfer roller or the laser scanning unit needs servicing to clean dust/humidity.
omnipresent
Nov 04, 2007 | Samsung ML 2010 Laser Printer
Dell 1320c Laser Printer Logo
24 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
