When the Onkyo is switch on and the tuner was selected there is a great chance it starts normal. But moste of the time there is no sound on the speakers. Al relais are working and when I wait (5min, 10 min, or much more) suddenly it works. When I switch to another input channel it starts al over, no sound and when you wait long enough the sound will come. The pre-amp is working, I have sound on the outputs like the tape-output. I see that de fan is NOT working until the sound appears on the speakers, then it works. I have the service manual and have tried the adjustment and confirmation procedure. The voltages mentioned are correct, the relais are working normal but the test of the DC detection circuit doesn't work. Measuring is very difficult or even impossible so I hope that someone knows the reason of my problem. Many thanks.
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Dec 26, 2012 | Wharfedale Audio Players & Recorders
Apr 17, 2012 | Onkyo Audio Players & Recorders
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 27, 2011 | Onkyo Audio Players & Recorders
May 08, 2017 | Onkyo TX-SR605 Receiver
Jan 05, 2010 | Onkyo TX-DS575 Receiver
Jun 22, 2009 | Onkyo HT-S780 System
May 06, 2008 | Onkyo TX-SR605 Receiver
Jan 18, 2008 | Onkyo TX-SR502 Receiver
May 29, 2007 | Onkyo TX-DS555 Receiver
346 people viewed this question
OK, but what must I check there ? I think that the output of the preamp section is muted. All mute signals are high and I'm waiting now for sound on the speakers so I can measure the mute signals then. So what is the cause of the mute ? When the sound is back, the receiver is playing until you power it off or select another input. It seems to me that there is no basic problem then.
I have here a service manual but it is a poor document (only 31 pages for such a receiver). There are adjustment and confimation procedures but there is no description what to do when something is not working as it shoot. Like the procedure on the confirmation of the DC protection circuit, when I perform this procedure, the speaker relay doesn't turn off. Ofcourse, the signal is muted but there is no description what to do then as is other service manuals is often described. (I hope my English is readable...)
The problem is solved at this moment. I don't know the why but when I had removed the contoller board (there seems to be some oxidation on the 'big' capacitor) and put it back in again, then there was no problem anymore...
I have a Onkyo TX-904 that I have had for years and suddenly developed this symptom where the sound may or may come on (usually not). You may hear a loud click and the sound will be on and maybe go back off. I read on the Internet that this is a common problem with Onkyo's as the DSP board goes back and the capacitors start to leak. I do not know where the component is to replace. Or I would be happy to jumper it so that there is no mute capability if that would fix it. Anyone know how to find the part at fault?
