Question about Microwave Ovens
Is it possible for a GE Advantium (PSB2201) to turn itself on? I awoke this morning to a strange sound in my kitchen. The thing was running full blast and hotter than hell! It does not seem to have
PSB2201NSS 01 2009 model 12O VAC. ...
    New Friend:
  • 28 Answers
Yes, it is possible. And it's dangerous. If it isn't under warranty, or you can't have it repaired. I suggest unplugging it when it's not in use.
Posted on May 02, 2013
freetek
  • 5568 Answers
SOURCE: Turntable
Remove the glass table and watch the drive spindle to see if it is turning when the unit runs; just put a cup of water so the magnetron is not without load, they can be damaged otherwise.
If it doesn't turn, gently try to turn the spindle with your fingers.  If it turns manually, then the motor has failed. If it doesn't, then some foodstuff has managed to freeze the spindle.
In the latter case, pull the plug from the wall, use some foaming cleanser (it's less wet) and try to get some under or around the spindle. Let it soak overnight, then try to turn the spindle with your fingers again.  If it's now free, mop up and remove as much of the remaining cleanser as you can, leaving the table out, put a cup of water or preferably a bowl with more volume, in the unit, let it run for some minutes to try to dry the rest of the cleanser out.
Put the table back in to see if it will now turn.
If this doesn't work, it will be necessary to replace the motor.  Since this is a unit I don't know, I can't predict if it is a DIY project or not and the dealer may ask an unrealistic price for the replacement.
Posted on Sep 11, 2008
  • 5 Answers
SOURCE: GE Advantium SCA1000.
I fixed this yesterday, using the solution posted here: http://forum.appliancepartspros.com/microwave-repair/4882-advantium-turntable-light-always-main-relay.html
Unplug the unit.
Replace the interior light using these instructions: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/ The inside of my unit looks a bit different from the pictures, but the procedure is basically the same.
Additional info not in the procedure link above:
Remove the one screw at the top of the front control panel.
Slide the control panel up to disengage it, and pull out slowly (has wires on back)
There are four black rectangular things running top-to-bottom on the PCB board on the back. One of them is labeled RY1.
Tap on RY1 with a screwdriver a few times (very high tech). I actually tapped on all of them for good measure.
Reassemble, see if everything works now.
It took me about 30 minutes for the bulb and the control panel 'adjustment'. Everything is working now.
Posted on Nov 18, 2008
  • 91 Answers
SOURCE: Killed the microwave by running it empty for 30 minutes.
YES THERE IS AN INTERNAL FUSE OR DIODE YOU CAN CHANGE, BUT YOU SHOULD BE CAREFUL AN LET A PRO DO IT, YOU JUST DON'T WANT TO GET ZZZAPPPP WITH THE CAPACITOR THAT STORAGES HIGH VOLTAGE INSIDE TO PROVIDE THE MICRO WITH POWER, IT MAY SEEM LIKE A LIL UNIT BUT IT CAN HURT YOU IF YOU DONT DE-ACTIVATE IT RIGHT, NOT SURE IF THE DIODE WOULD BRING IT BACK BUT CHECK WITH A SERVICE MAN, BEFORE DOING ANYTHING I WOULD!
Posted on May 28, 2009
  • 186 Answers
SOURCE: Problem with the GE Advantium
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Posted on Jan 29, 2011
  • 68 Answers
SOURCE: GE Advantium Oven Noise
Most are eqipped with a small cooling fan that allows the unit to cool down quickly..fan may need replaced
Posted on Jun 07, 2012
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Jun 07, 2012 | GE Microwave Ovens
GE Advantium SCA2000Bww03 microwave runs but dose not heat
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The first thing I would check is the upper & lower door switches and switch mounts.
My help file on door switches is here.
Oct 09, 2011 | GE Advantium SCA2000B Microwave Oven
Strang Metal flapping noise
Is it like the sound in the video?
If so, it may be a bad damper control switch or the damper assembly may be binding.
If it's new, then it should be fully covered under warranty and GE should send a servicer out at no charge. GE Customer Service is here.
If it is not under warranty, then w
e have the service manual for this model and have uploaded it for you here.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 12, 2009 | GE Advantium 120 Convection/Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
I want to replace the door
I do not think you can change the door. I can be wrong though. call ge at the number on this link.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SCA2001KSS&SITEID=GEA&TABID=3
Good Luck and Please Rate
Jan 07, 2009 | GE Advantium SCA1001SS Convection /...
Microwave not heating every time...
You seem to be having a problem with the interlock device. when you close the microwave door it is supposed to hit a series of 3 switches to tell the microwave every thing is safe and able to run. you may want to take the control panel off and make sure those switches are ok. usually out of the 3 switches top and bottom should be open middle should be closed. you could check with the continuity side of your electric meter.
Let me know if you have any questions before rating me.
Nov 15, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
