Question about Activision Heavy Gear for Windows
Heavy gear Hi, what do I need to do to get heavy gear to run on windows 7 64 bit?
2001 chevy prizm jerks when in gear heavy smoke out of exghuast
It will help Matt if you would have said what color the smoke is thats coming out the tailpipe. White heavy smoke will be antifreeze getting in the combustion chamber.Could be head gasket,cracked or warped head.Black smoke would be fuel system pumping gas in making it run rich,And not able to burn the fuel completly.
Feb 06, 2014 | 2001 Chevrolet Prizm
HP Pavilion DV7 freezing during charging
When your laptop goes on battery power the processor automatically gears down to conserve battery power, but when charger is used the processor goes to full power and you run heavy programs drawing more resources, I suggest you upgrade your ram because heavy gaming uses more ram memory.
Jul 04, 2012 | Computers & Internet
How can I load the 32 bit program on a 64 bit machine?
I will assume you are using Windows Vista or Windows 7, which is a newer operating system then what the game was intended for. Microsoft Windows has a Compatibility feature you can use to run games in Compatibility mode. Once you install the game, you can right click on the game Icon(should be on your desktop) then choose properties. In the properties go to the Compatibility Tab and click Run program in Compatibility Mode and in the drop down box try selecting Windows Xp(any service pack). Also check the Run Program As Administrator. In some cases you can get the older games to run.
Sep 28, 2011 | Groove Games Marine Heavy Gunner for...
I have the heavy gear . i've changed my joystick, but the game doesn, recognize the new one
In Windows 7, Go to "Game Controllers" in your control panel, select your joystick from the list, click "Advanced," and under "Preferred Device" select your joystick from the dropdown menu.
It worked for me with my MS Sidewinder FF2 and Windows 7. BTW, SloMo is highly recommended to play Heavy Gear 1, as otherwise your gear will run in place in the game because it's running too fast.
Feb 27, 2011 | Activision Heavy Gear for Windows
Why does my bike start on warm days but not on cold ones?I already replaced the starter
are you running 20w50 oil? if yes, probably full synthetic. try running a standard 10w40 oil or something not as heavy as what your using. heavy oil in combination with cooler weather makes for heavier oil, harder for your starter to turn the gears through it. warmer days, gears move easier.
May 09, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
Gear change
hi,this is quite a common problem on these,before you put it into gear pull the lever in two or three times,this will loosen up the clutch plates a little,if i am right it normally only happens when the bike is cold?,the cause is the oil in the gearbox(wet clutch)is probably a little bit heavy,this is why bikes use a multigrade/friction modified oil,hope this helps...cheers
Apr 29, 2010 | 1984 Yamaha XJ 600
Renault megan 1998 diffucult to get into 1 st gear
Hi, My postmans Megane has the same grief, I tried changing the power steering fluid but made it worse, looks like the pump itself.
If your clutch is heavy to then the cable is possibly stretched and needs replacing.
Oh Make sure there aren't any carpets under the clutch stopping the full travel of your pedal.
Good Luck.
Paul 'W'
Onyer~EDson(:0) {#><
Jan 13, 2009 | 2004 Renault 181
Activision Heavy Gear for Windows Logo
16 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
