Samsung marker has stopped working - Computers & Internet
Samsung marker stopped working! help
Posted on Oct 01, 2013
How can you tell if a Samsung i577 has ever been wet
it is either on the last botton screws or inside the logic board panel
Mar 03, 2014 | Samsung SGH Cell Phones
Ice marker not working
I had a problem with mine when a piece of ice jammed the comb that ejects the cubes. No ice being made until the jamming ice cube was removed.
Nov 07, 2013 | GE Profile PSW26P Stainless Steel Side by...
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have a 99 Pontiac Sunfire, 2.2L and my turn signals quit working. I replaced the combination switch and the flasher/hazard relay, and still no joy. The problem was intermittent, and now it's just dead....
It will turn on when I hit the button and the turn signals do work. All of this has led to my ABS lights to come on as well. ??????????? Your best bet , take it to a qualified repair shop or learn to do better explanation's ! Or lean to do automotive electrical testing .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Electric Testing Techniques You Need to Know
How to Use Multimeter to Troubleshoot Common Problems
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year make ,model and engine size. Under system click on lighting ,then under subsystem click on turn signals . Click the search button then the blue links .Check power an ground circuits ! This is how we diagnose electrical faults , not just replacing parts .
Turn Lamps
Voltage is applied through the TURN fuse and the turn/hazard flasher when the ignition switch is in the following positions:
• RUN
• BULB TEST
• START
The voltage travels to the contact in the hazard switch. The hazard switch is located in the turn/hazard-headlamp switch assembly. This contact is normally closed.
When the left turn signal is turned on, voltage is applied to the following components.
• The left turn indicator
• The left front park/turn lamp circuit 14
• The left rear turn lamp circuit 18
The turn lamps turn on immediately. The current flow heats up the timing element. The timing element is located in the turn/hazard flasher. The timing element repeatedly opens and closes the circuit. This action causes the turn lamps to begin flashing.
The voltage that is applied to the left front park/turn lamp is also applied to the left front marker lamp. If the headlamp switch is in the OFF position, the left front marker lamp will find a path to ground through one of the following lamps. The following lamps provide low resistance paths to ground:
• The right front marker lamp
• The right turn indicator
• The right front park/turn lamps
• The left front park/turn lamps
The left front marker lamp flashes with the turn lamps. The voltage drop across the marker lamp is much higher than the voltage drop across the other lamps. The lamps that are used for the ground path will not flash.
When the headlamp switch is in either the PARK or HEAD positions, voltage is applied through the following components:
• The EXT LP fuse
• The marker lamps
• The park lamps
When the left turn signal is turned on, the left marker lamp will have voltage at both connections. The left marker lamp does not light. When the turn/hazard flasher stops the voltage to the turn lamps, the marker lamp is grounded through the turn lamp. The marker lamp does not go on. The left front marker lamp flashes in the following manner:
• The left front marker lamp flashes on when the turn filament of the left front park/turn lamp goes off.
• The left front marker lamp flashes off when the turn filament of the left front park/turn lamp goes on.
Voltage is applied to the right lamps in the same manner, when the right turn signal is turned on.
Hazard Lamps
Voltage is applied at all times through the following components to the normally open contact of the hazard switch in the turn/hazard-headlamp switch assembly:
• The STOP HAZ fuse
• The turn/hazard flasher
When the hazard switch is turned on, voltage is applied to the following components:
• The front turn lamps
• The rear turn lamps
The following lamps flash on and off:
• All of the turn lamps
• Both of the turn indicators
The front marker lamps flash with the hazard lamps on, just as the front marker lamps flash when the turn lamps are on. If the headlamp switch is in the OFF position, the front marker lamps flash on when the hazard lamps are on. The front marker lights will flash on when the hazard lamps are on if the headlamp switch is in one of the following positions:
• PARK
• HEAD
When the hazard lamps are on, the following conditions apply:
• The turn circuit is always open.
• The turn/hazard flasher controls the lamp.
Park/Marker Lamps
Voltage is applied through the EXT LP fuse, to the headlamp switch at all times. Voltage is applied to the park lamps and the marker lamps when the headlamp switch is in the following positions:
• PARK
• HEAD
The front marker lamps are grounded through the turn filament of the respective front park/turn lamp. The front marker lamps light as a result.
Stop Lamps
Voltage is applied through the STOP HAZ fuse to the brake switch at all times. When the brake pedal is depressed, the brake switch closes. This action applies voltage through the turn/hazard-headlamp switch assembly to the following lamps:
• The high mounted stop lamp assembly
• The left tail/stop-turn lamps
• The right tail/stop-turn lamps
Jun 30, 2017 | 1999 Pontiac Sunfire
Had a problem with a right, amber side marker on right side
Usually one of the holes in the marker light where screw goes in, has metal contact where screw meets light, but if not, and they are not push in wire connection type from behind, then just run your white wire up through hole in housing, and bare the end & tighten it up under screw holding light to body. White should be ground, brown should be power.
Jul 02, 2009 | 2004 Dodge Ram 2500
Right side of trailer running lights does not work
My stop light work intermitent when the marker in
im thinking its a fuse check thqt first then if that dont do it then you might have a blowen tail light or one that's about to go out
Jun 07, 2009 | 1995 Volvo 850
2005 Chevy Tahoe Trailer Running Lights Out
Depending on what type of trailer you have, a blown lightbulb on one marker could kill them all (like the old Christmas light strings). Look at those, and make sure your ground is good.
Nov 26, 2008 | 2002 Saturn VUE
Computers & Internet Logo
1,192 people viewed this question
David Payne
David Payne
