Question about Pick Hot Wheels 79 Ford F-150 Pick-up 1/64 Limited Edition
I have a 1979 ford f 150 that wont start iv put in a new alternator, new battery,new battery cable, new fuel pump, fuel filter, new soleniod,new diaphragm assy.,pump. tryed to start it nothing happened it sounds like it wonts to start but it does not iv checked the coil and the spark plugs they are good
    New Friend:
  • 28 Answers
Does it make any kind of noise? Is the battery working? Have you checked the starter?
Posted on May 02, 2013
I have an 2003 ford expedition that just stopped . i first changed fuel filter, fuel pump, cleaned injectors, changed filters, spark plugs, cleaned throtle, then had it checked further and tjhe mechanic...
Probably the inertia switch for the fuel pump..You owners manual should show you where its located..See if the button has pop up ..If it has push it back down until it clicks..If it wont stay down then hold it down and see if it will start..If it does you will have to replace it..If thats all good then check the relay for the fuel pump..
Sep 07, 2011 | 2003 Ford Expedition
MY 1990 F-150 W/302 RUNS GREAT BUT AT TIMES EITHER WONT RUN OR RUNS REALLY BAD I HAVE REPLACD ALMOST EVERY PART RELATED TO ELECTRICAL AND FUEL RELATED COMPONENTS. ANY HELP WOULD BE GREATLY APRECIATED
basics-compression, electrical (battery, alternator), ignition (plugs, plug wires, ignition module, dist cap and rotor), fuel (fuel pump, filter, injectors, throttle body, regulator), management (engine computer)-petty much in that order.
An intermittant problem is usually electrical (primary or secondary ignition) so a voltmeter that measures resistance/continuity is a valuable tool. New and known-quality parts are better than cheap, Chinese knock-offs that might be junk out of the box but you are ignoring them becasue they are 'new'. Another good investment is a good OBDI scanner to see if you have a code since you have a EEC IV system which has particular weak points (like the pick up module). Grounds are also points of inspection and have to have good cables and immaculate contact surfaces free of rust.
Mar 23, 2011 | 1990 Ford F150
1979 ford granada wont stay running. i have replaced plugs, dist. cap. fuel pump fuel filter alternator...
substitute a known good coil.I understand it'll start and run for awhile?...it could be that the fuel system is vapor-locking.
Nov 03, 2010 | 1978 Ford Granada
1979 chevy step van 350 new fuel pump rebuilt carburetor wont sta
remove the fuel line from the carb, put it into a bottle, crank the engine, If the bottle has fuel in it the fuel pump is working properly, if not, check the filter, and the fuel lines to the tank!!!
Nov 02, 2009 | 1979 Chevrolet C/K 3500
1993 Ford Thunderbird- New battery & alternator & car won't start
if the car is an auto please check the switch on your auto box also starter soleniod part of starter motor try and check power to soleniod when turning key and check your soleniod connections
Jan 13, 2009 | 1997 Ford Thunderbird LX
1979 Ford F-150 wont start. NEED HELP ASAP
change your neutral safety switch and then your truck will fire right up
Jan 10, 2009 | 1981 Ford F 150
Open Questions:
See all Pick Hot Wheels 79 Ford F-150 Pick-up 1/64 Limited Questions
Pick Hot Wheels 79 Ford F-150 Pick-up 1/64 Limited Edition Logo
71 people viewed this question
Top Pick Toys Experts
ray gallant
Are you a Pick Toy Expert? Answer questions, earn points and help others
