Question about Wega Mininova EPU Espresso Machine
Wega espresso soon as its on temp,it just releases steam
    Scholar:
  • 70 Answers
Steam out of the top is a bad safety valve.
Steam out of wands when they're off is bad gaskets in the valves which usually means they need to be rebuilt.
Steam out of groups is a water blockage and/or pressure stat is going bad and causing the machine to over heat.
Can be any one of the following. Need more information to answer properly.
Posted on Jul 11, 2014
Need replacement steam wand wega epu 2
wega epu. Commercial machine. I'd check espressoparts.com. Any faema, wega, nouva simonelli wand will screw into the wega valve.
They also have precision wands from japan. Sproline series i believe it is called.
I have no association with the site but i do know that any of the parts Listed will work.
Oct 04, 2013 | Wega Coffee Makers & Espresso Machines
Alarm steam temp (this masseg i get as soon as i start the machaine)
The temperature probe in the steam boiler is faulty and needs to be replaced
Jun 17, 2012 | Nuova Simonelli Microbar Espresso Machine
Wega Espresso Machine is slow to recover steam pressure
Bad pressurestat or bad heating element. PS feeds power to heating element, heating the machine til its up to pressure, which then turns the pressure stat off. If either of the two pieces are bad neither will work properly.
Could also be the machine is overfilled which causes the machine to take longer to heat up.
Sep 20, 2011 | Wega Mininova EPU Espresso Machine
We have an old Wega model EPU1(grey/burgandy) it is not frothing too well. It is as if there is water diluting the milk and the froth contains very large air bubbles, any ideas on what we we need to do...
i believe, if i am understanding this, as i guess here, when you are frothing the milk, it seems to also fill up faster, like water is not steaming as much as it is filling. As you know, steam is hot water turned into steam, now what is happening the steam is half steam and half water. If this is the symptoms along with air bubble, then it points to O RING replacement, direct water is getting through before it has time to steam, on a commercial type machine, you are better off to have a mobile espresso guy come out in your area, replace the o ring in the wand, and also make sure no other damage has been cause from back water pressure on electronics. I hope this helps, this is a do it yourself job, but would not recommend if you really don't know about guts of the machine and electronics. The computer is the major expense of the machine. Thanks Mike
Jun 12, 2011 | Wega Mininova EPU Espresso Machine
#1 Thermostats are not working properly #2 I have
Using an ohms meter check the thermostats and replace the broken one, I think it is most likely the coffee thermostat.
Sep 27, 2010 | Rancilio Silvia Espresso Machine
Wega mininova - steam wand not functioning
try cleaning steam tip with small paper clip. if coffee is hot then steam wand is blocked. Try using a de-scale solution.
Sep 20, 2009 | Coffee Makers & Espresso Machines
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Wega Mininova EPU Espresso Machine Logo
64 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
