Question about Black & Decker 18", 6.5a Electric Mower
Mower is electric. cord is fine. was mowing great, had it on highest blade level due to high grass. just quit completely. blade and chute are not clogged. there is power to mower.
  • 2,533 Answers
If you were cutting long grass it sounds like you may have burnt the motor out. It may have over heated. they are not made to cut long grass. You don't say whether the motor runs but not the blades if this is the case you may have sheared the shear pin in the blade assembly.
Posted on Jun 28, 2016
frcs68
  • 1605 Answers
SOURCE: electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
Posted on May 22, 2009
  • 279 Answers
SOURCE: Why does my electric mower lose power in high
The high grass causes more drag than shorter grass. This means more friction. The tilting lessens the drag, so less friction, the speed increases. It ma need a sharpening but it sounds as though it is running correctly. As you say, it is older so you can't expect new performance. Good luck...Lee
Posted on Sep 17, 2009
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
  • 52 Answers
SOURCE: 19" black and decker electric mower just quit!
check the brush on the motor the one with the black wire usally wears first
rycgl
  • 1545 Answers
SOURCE: i tried to mow the grass even though it rained
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Posted on Aug 14, 2011
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
Mower is not picking up grass plugging in chute
Did you just replace the blade ? If so, it might be on upside down, which would produce no upward suction.I assume you're not mowing right after rain. If there's a buildup of old grass gunk around the chute, scrape it off. Remember always to pull the plug wire off before reaching under the mower!
Mar 07, 2015 | Garden
Wont start
May 02, 2013 | Black & Decker 18", 6.5a Electric Mower
Craftsman 18.5 HP Lawn Tractor PTO will not engage
did you break the deck belt?did you over load the electric clutch and blow the fuse?
Aug 06, 2012 | Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Black & Decker 18", 6.5a Electric Mower Logo
75 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
