Question about Black & Decker 18", 6.5a Electric Mower
Wont start was running fine...had it at highest blade height, abruptly stopped, blade and chute are not clogged. Has power
  • 2,027 Answers
If you were cutting long grass it sounds like you may have burnt the motor out. It may have over heated. they are not made to cut long grass. You don't say whether the motor runs but not the blades if this is the case you may have sheared the shear pin in the blade assembly.
Posted on Jun 28, 2016
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
Why does unit run sluggish when blades are engaged?
if you are talking about before even moving, it could be grass and dirt caked inside of the deck. If you are talking about when you start mowing, it could be front to back height adjustment. owners manual has instructions for adjusting deck height.
Jul 24, 2014 | Craftsman Garden
Mower is electric. cord is fine. was mowing great, had it on highest blade level due to high grass. just quit completely. blade and chute are not clogged. there is power to mower.
May 02, 2013 | Black & Decker 18", 6.5a Electric Mower
Won't cut on low height setting
there are several rods that support the deck if one is missing it can allow the deck to move in the wrong dirrection
May 22, 2012 | Garden
Toro 20017 clogs up all the time even if grass is mainly dry.Have moved the height up but still contines to clog
This is not a safe fix,but it works.Tie a string to the top of the chute the grass comes out of.Lift it just a lil and tie off the string.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
I want the length of my grass taller. How do I adjust the blade to achieve this? Or is it the wheels?
Hi, are you saying that you want it taller than the highest blade setting? Meaning the highest notch on the blade height setting lever?
May 06, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Dec 17, 2009 | Garden
Pull-start rope won't pull
This has happened several times for me and is usually caused by a peice of word jamed in the input hopper and half cut by the blades. Always make sure there is no wood in the input chute before stopping motor. remove the collector bag and use a long pry bar to reverse the flywheel. if this moves backwards you may then be able to remove the peice of wood jammed in the blades thru the input chute. Long Skinny arms is required to reach down the chute. Use a Flashlight to see if this is your problem.
Jun 26, 2009 | Troy-Bilt Chipper Shredder
Black & Decker 18", 6.5a Electric Mower Logo
77 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
