Question about OKI C9600hdn Laser Printer
Oki not printing pink
Hi i have bought the oki c9655 and the pink is not printing well ,it is more a dirty peach colour,i dont no if its because my inkjet has lovely vivid colour which i no lasers arnt as good but i have been dissapointed so many times with this printer.they are the toners that came with it and has moved down 1 bar so it cant be they need replaced ,is there any way to make it nice bright pink? the darker oranges and reds print lovely hope some one can help mandy
  • OKI Master
  • 838 Answers
Seen this many times. Its because you are using recycled drums and/or toner. With the genuine items you will find the magenta will be more red than pink.
Posted on Jun 22, 2017
Soulvisitor
  • 1113 Answers
SOURCE: OKI 5600 - Can you do a 'clean'?
Clean Cyan led head (on lid)
Replace Cyan drum with new
Posted on Dec 20, 2007
SOURCE: STREAKS WHEN PRINTING
Thank you. I will go check into this and see if this helps.
Posted on Mar 16, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
SOURCE: OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Posted on Feb 12, 2009
shawn38
  • 200 Answers
SOURCE: I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Posted on Feb 19, 2010
Error code 480 on my Oki C9655
480 is not listed in any OKI manual. However the closest to it refers to paper size mismatch. Check your driver setting especially paper size. If in UK make sure its set to A4. if in USA then yours is letter size.
Jun 04, 2018 | OKI Office Equipment & Supplies
How do i fix my OKI C9655?
Most likely needs service. To many things wrong at once.
Jan 29, 2015 | OKI Office Equipment & Supplies
Why xerox phaser 6360dn is printing only pink
Anonymous, Have you tried to print the test print, is that Pink?
Have you tried too print the configuration sheet, is that Pink?
Have you tried to run purge sheets are they Pink?
If the answer is yes to all the above then has the printer been moves whilst still hot or warm, you could have mixed the colours.
If all the colours were mixed together then you would have a dark dirty Brown. Further investigation needed.
Good Luck.
Sep 05, 2014 | Xerox Phaser 6360 Laser Printer
I bought a new Oki C610 a couple of months ago to start up a custom art business. From the beginning, the DCT 4.5 paper has stuck to the fuser roller. With the first fuser cartridge, it just dog-earred on...
Hi my reply was too long heres the second half..and ill retype the first as a comment
Try printing lighter prints, heavy toner saturation causes paper to stick to fusers and try to keep leading edge of print blank with no big blobs of colour for the same reason, ensure page sizes are set correctly in driver and machine tray settings and dont print outside margins , if you are about to print outside margins your printer driver should warn you, dont click ok if it does
Here is your user manual for your oki. and a link to oki print drivers to suit 610
Here is a link to Magic touch Australia that i thought has some good info re transfer paper use
Ensure your printer works ok with plain paper so we know it aint a printer fault but I'd say it due to how we are feeding the paper and how we have the paper type set and not feeding out the rear as I also think we should be.
Oki does the best colour prints nice and glossy, I dont think many come close to such great colour prints in fact I only like Oki and Kyocera stuff in Colour toner laser machines. Stear clear of cheap non oki toners and supplies because they cause heaps of issues and wreck printers and give many print quality issues, I dont work for OKI directly just telling you how it is in the field ;)
Let me know if you need more help and how you go
Cheers
Steve
Nov 05, 2011 | OKI Office Equipment & Supplies
My oki c3300 laser printer has suddenly started printing pink on blank pages?
Pictures printde on OKI c3300 sudenly coming out very pink. No alterations made to printer or computer settings.
Any isddeas please
Jan 12, 2010 | OKI C5100n Laser Printer
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
May 13, 2009 | OKI C3100 Led Printer
OKI C9600hdn Laser Printer Logo
96 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
