Question about Lands Phones
Nec t20sm1 down volume
How do I turn off DND????
For the NEC DSX DTL-8R-1, try pressing and holding the Volume Down button on the handset for 2+ seconds while the phone is in standby mode. This press and hold option toggles the Ringer Mute feature. It works when an incoming call is ringing or in standby.
The manual for the this phone is available online here: http://www.teamextenda.com/download/nec/NEC_DSX_Cordless_DECT_UserGuide.pdf .
I hope this helps.
Oct 31, 2014 | NEC DSX DTL-8R-1 DECT Phone
Sound card NEC laptops
What is your question? The volume is located in the Tray Notification Area, Sound icon, right click, adjust volume.OR , open Control Panel, Sounds, adjust.
Dec 17, 2012 | NEC Versa Computers & Internet
I cant get my NEC speaker to work for my computer. Is there a specific plug in the monitor that it goes into? Or do you need a software?
click start control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 06, 2011 | NEC Orca Jazz Speakers Assembly Kit...
Incoming ring volume
It has been my experience with these office phones, that you need to change the volume while somone is calling or while the phone is ringing. Try that, have someone buzz the phone, then while it is ringing, click the volume button up or down.
Sep 10, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do you turn the ringer off of an NEC-DTU-32D-2?
you need to remove ringing programming in 4-01 for that extension. ldtsnj.com
Feb 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
Turn Volume Down
Yes while the phone is ringing use the down arrow key and it will lower the volume.
Sep 09, 2008 | NEC Electra Elite 32D-1 Corded Phone
NEC Dterm 80 / change contrast on display panel
Use the up/down arrows on the bottom right. Though you may think they are volume, it actually is for contrast when the phone is on-hook.
Apr 01, 2008 | NEC Lands Phones
We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Mar 24, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Ringer volume
Adjusting the ringer will depend on the type NEC system you have. On the PRO II, Elite, and IPK just press the Speaker button and dial 601. The Phone should begin to ring and you can then adjust the volume with the up and down arrows.
Apr 19, 2007 | NEC DTU 16D-2, 770032 Phone (Refurbished,...
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
