Question about Rinnai E75CN Condensing Boiler
Rinnai E75 always displays FILL
January 2012 - I had a Rinnai E75cn system installed to replace an older Hydrotherm unit and 35g tank. Over the past 6 months it displays FILL quite often, and I have no heat/hot water when it does so. I have tried pressing the "R" button to reset it, and sometimes it works, most times it doesn't. I believe the system is saying it is low on water, and needs to be topped. I just can't find anything to outline these steps in better detail than what the manual says. If this is normal I need to know, if not normal, then something is wrong, and after only 16 months, there shouldn't be anything wrong with it. Other details: There is a flow-restrictor on the main water-in, set to 80psi. Without it, flow was over 120psi, too much for the system, so I was told. An Aqua-Pure water filter was also installed, prior to the flow-restrictor, and I change the filter on a regular basis, when it looks dirty.
    Habit-Forming:
  • 31 Answers
I'm sure you've resolved this by now! However, for anyone else looking, with any boiler changeout it seems to disturb any sediment that may have been in piping for some time for many reasons.Also, excess solder or flux chunks can create havoc. Any valves, restricters, prv can get gunked up in the process. Usually it gets stuck slightly open. Some have screens that get clogged as well.
Posted on Nov 05, 2013
  • Ricka182 Nov 06, 2013
    I wound up calling the installer back.. He called Rinnai. They came to the conclusion of a very small leak from behind the foam insulator was causing the pressure to drop over and over. It would drop due to the leak, then eventually fill up again after multiple reset cycles, then drop again. Due to the heat, it was pretty much evaporating, sans a little bit that dried on the copper below, so I never woul dhave seen it. It's been working like a charm since then, no issues. Thanks.
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai 556F stuck on Low and will not produce heat
The Low code indicates that the heater did not start because of lack of gas or that the flame rod did not sense enough heat. Make sure all gas valves are on and if you use propane gas, that it has gas in the tank.
Assuming all gas is on, you will need to remove the front cover by first pulling off the very bottom trim piece. This is located below the louvers and by grasping both left and right sides of this trim, pull toward you. It is just held in place by little clips. Now taking a very new #2 Philips head screwdriver, remove 2 screws found on the extreme left louvered section of the front. Then 2 more on the extreme right. Two more near the center of the louvers. Now I think there are two more holding the bottom in. Gently move back and forth the front panel starting at the bottom and work out the clips at the top just below the instrument area. Be careful to not break any of the clips at the top. With the front off, at about the 5 o'clock position you will see a very small round hole with glass over it. Start the heater and look to see if it ignites and stays on for a second or two. If it does but goes out very quickly, you may have a corroded flame sensor. The flame sensor is located by looking into the small hole and up to the 11 o'clock position. All it is is a probe that sticks down. The only way to get to it is by removing the small window section of the heater and use a wire brush used to clean a gun and brush it. Or very gently take a thin but long regular screwdriver and scrape off the probe. Be careful not to damage the fragile white gasket when taking off the sight port.
If the heater never started, you have a restriction in the gas train. Typically I find that spiders make a nest inside the gas burner because the bugs they eat likes the gas smell. The only way to get to their web is to remove the burner from the unit and clean it. This is not an easy part to remove and suggest you call a technician.
Good Luck!
Posted on Nov 04, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Ductless heater shutting down
There is a small wiring harness that goes from the main board down to the sparker board at the very bottom of the heater. Disconnect this harness and reconnect making sure all pins and contacts make good connection. If it continues, replace the wire harness. Also make sure the outlet that the heater is plugged into is a grounded outlet. Stray voltage can interrupt the thinking of this unit.
If all connections are good and the unit is grounded, you are probably looking at replacing the sparker board. I do have these parts and would be more than happy to send them to you for a donation.
Posted on Jan 18, 2008
  • 330 Answers
SOURCE: Rinnai Infinity instant hot water
call the installer back
Posted on Jul 03, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Max temperature for Rinnai 556WT restricted to 74 degrees
There is no way to restrict the setting and keep it UL approved. If you cannot get the heater above a certain setting you have either too small of a heater, too much outside air entering the apartment or the gas pressures are not great enough.
Posted on Feb 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: My Rinnai says not to use it without an air filter
If you have a RHFE263, 431 or 556, the air filter is located at the top in the seam where the wall trim piece attaches to the heater. It looks like a dryer lint filter.
Posted on Feb 15, 2010
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
Had an opella flush system fitted in January this year, now the cistern doesn't fill up after the toilet is flushed, unless the cold water tap is turned on. Can you advise? Feel I should call the plumber...
The fill system should have a small tube that runts down an open tube in the tank to the cistern. Remove the tank lid and place the tube back in the round tube about 3/4' in diameter and open.
Dec 16, 2014 | Home
Why is my Rinnai Infinity 20 leaking?
Hole in heat exchanger caused by improper condensate drain?
Read installation manual, call service technician.
http://waterheatertimer.org/pdf/Rinnai-Tankless-Troubleshooting-Manual-2012.pdf
Replace with tank type heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Oct 01, 2014 | Rinnai Water Heaters
Error code 71
Absolute best solution for Tankless water heater is to replace whole thing with tank-type water heater and quit spending money fixing an old computer with multiple sensors that is connected to your water pipes, electric line, and gas line, that is connected to a gas burner with vent pipe to outdoors ... As if each of these systems doesn't have a load of problems on its own without a computer chip.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
Otherwise, I do not have a source of information that is better than a service manual.
Apr 24, 2013 | Rinnai R75LSi Interior 7.5 GPM Natural Gas...
Unit will not lite
Look on the circuit board, is ther a flashing diagnostic code?
tell me this code sequence.
Typically an induced draft motor will be the first thing to run, is this running? is the pressure switch for the induced draft operating, it its tubing and the tubings ports clear?
is the condensate line clear?
is the flame sensor clean? use 0000 steel wool to wipe it off.
Jan 22, 2013 | Rinnai E75CN Condensing Boiler
Canon W8400 E02804
Check x Tank (the ink color is indicated by x)
This is displayed when an incorrect ink tank is installed.
The final digit indicates the ink color.
So you have problem with Bk ink tank...
This is displayed when installation of an incorrect ink tank is detected.
This is displayed when a checksum error occurs in the ink tank EEPROM.
Ink tank, ink tank unit, engine controller, system controller
1. Replace the ink tank.
2. Replace the ink tank unit.
3. Cable connection check
Replace the cable between the ink tank unit and engine controller if the connection is not functioning normally.
4. Replace the engine controller.
5. Replace the system control
So as you can see there is a lot of possibillities, ... call service
Aug 08, 2011 | Canon imagePROGRAF W6400 InkJet Printer
How to test a used Rinnai 1004 furnace?
The fitting on the back of the unit is 1/2" MPT. Wouldn't suggest messing with it if you are not familiar with propane or natural gas. Make sure the unit is set up for LP if you are going to use a portable supply tank. These units are very reliable. Check all fittings with a diluted soap and water solution before turning on the unit. If it is not connected to it's venting system, you would have a forced induction source of ignition if you had a leak in your piping. These units should only be installed by a licensed plumber or gas fitter, one simple error could allow carbon monoxide (CO) into your house
Aug 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Our second unit just failed and needs a new controller more money
The only Bosch tankless I have ever touched have been the 3 I have taken out and replaced with Rinnai. I think Bosch/Paloma/etc. have two problems:
1. They do not properly certify technicians before allowing them to install these units.
2. Their product is mediocre at best.
The biggest problem I've seen is that people don't vent them properly. The last one I pulled out had a combined vent length of 55'. 55 FEET! Absurd!
The units was condensing so much inside the vent that it washed out 2 gas control valves in ONE YEAR.
Buy Rinnai, buy Takagi, buy Noritz....maybe even a Navien (new player...time will tell)
Factory certified technicians, preferably equipped to do the gas & plumbing without having to sub it out.
Years of trouble-free hot water.
Good Luck.
Jun 30, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Rinaai LP space heater will not shut off when set temp is reached
Test the thermistor by using an ice cube. Place the cube on the thermistor and see if the unit starts. Then using a warm towel, wrap the thermistor ans see if it stops. Watch the display to see if it is registering the changes in temp. I suspect a bad thermistor.
Jan 02, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai E75CN Condensing Boiler Logo
475 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
