SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
SOURCE: Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
SOURCE: My Neff induction hob has prgressiely getting
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
SOURCE: we got an E3 error
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
