Question about Kitchen Ranges
Getting Error e8 after a couple of minutes on one of the IndusCation zones
Rangemaster professional plus induction
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on May 03, 2013
Rangemaster Professional Plus 110 induction. How do I lift glass hob cover to replace Hob display module
I believe you will find your answer on this site. In reading how someone else did it, some of the screws appear to be quite well hidden.
http://www.ukwhitegoods.co.uk/forumsphpbb3/removing-hob-rangemaster-110-t23376.html
Dec 19, 2017 | Rangemaster Cooktops
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
The door on my rangemaster 101 wont shut properly
John, it sounds like the problem is in the hinges. They are not aligned, even thought the seal has been changed, the door is not seated properly as a result the steam comes out. You will need to readjust the hinges. If this seems out of your comfort zone you may want to call a professional.
Jan 09, 2015 | Rangemaster Kitchen Ranges
New rangemaster prof.fx90 induction cooker but hob not working. - comes on if a ring is on if you touch the hob but no other lights come on + it won't heat up.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Nov 28, 2014 | Rangemaster Kitchen Ranges
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Rangemaster 110 induction hob not working
sounds like you will have to strip it to get to where the water is causing the fault
Jan 10, 2014 | Rangemaster Kitchen Ranges
Only 12 wireless zones 6150rf
The E8 Means to-many zones for you 6150rf to handle i suggest replacing to a 6160rf
If you need further help, reach me via phone at https://www.6ya.com/expert/joshua_f823c77053c73844
May 12, 2012 | Honeywell Ademco Alarm 6150rf Keypad Lk
I get E9 error from my induction cooker
If its a Rangemaster induction cooker, I had the same problem and its caused by a Loose or faulty PT sensor under the glass, you need a qualified engineer to rectify it.
Feb 08, 2011 | AEG 23 in. 68001KF-N Electric Cooktop
My dispay on my jura E8 says error 5.
Simple fix - got the machine serviced, needed a new thermoblock apparently, could also have been one of the couple of sensors they replaced. Total cost including box, bits and carriage - £180 plus change.
Expensive but now I have it back, it all seems worth it!
Nov 30, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
