Question about Home
We have a saniflo under our stairs and when flushing the toilet the pipe that goes into the box came out and flooded the floor. Any suggestions to why this has happened?
    Scholar:
  • 115 Answers
I guess you are talking about the discharge elbow on top of the pump, that is called a discharge elbow, they are usually clamped to the top of the pump casing to prevent it from leaking or blowing off. Make sure the clamps are properly tightened.
Posted on May 16, 2013
Smooth_Gecko
  • 125 Answers
SOURCE: The toilet was installed under the stairs a year
Take the lid off the cistern tank and have a look. There is a ( usually ) round float ball in there. This is what is causing it. When the cistern fills up the ball is supposed to float up and the arm it attaches to shuts off the water, usually at the opposite end to the float.
Turn the tap on the pipe to the cistern so it is nearly off and move the arm up and down by hand. See what it is getting stuck on or what is happening.
If it is not a simple sticking problem, you may need to undo the top of the cistern valve itself ( opposite end to the ball. )
Turn the water off completely to the cistern to do this or you will get squirted. :)
They are fiddly little valves and all a bit different but if you take your time and make sure you have a good light you will be able to work out what has been happening.
Hope this is some help.
Posted on Oct 17, 2009
  • 82 Answers
SOURCE: NOISY SANIFLO
Always an issue, guessing it is on a tiled floor? or up against a tiled wall?
I put some thin foam / Bubble wrap underneath and behind mine to dampen the vibrations. It also helps if you box the unit in and use foam to quieten the noise (on top and around the unit). Depending upon how long you have had it, it may also need a clean out or possibly even the motor bearings are getting a bit worn, creating some noise with the excess movement.
Good Luck
Posted on Jan 17, 2010
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
farmerbear
  • 490 Answers
SOURCE: I have a saniflo toilet
Any brand approved for septic should work well in the saniflow system, but the key is to use as little as reasonably possible and flush as you go. Big wads of any type will compromise the system.
Posted on Oct 11, 2010
packrat1948
  • 528 Answers
SOURCE: We have a saniflo. We
If the apple core was right at the pump intake at the time the pump kicked on it very well may have been the problem. The pumps in those units are not the strongest in the world anyway. They are not made to grind up anything that has any bulk to it.
So the answer to the question in my opinion is yes. But you well want to keep a close eye on it for a while.
Posted on Mar 11, 2011
Testimonial: "Very helpful - thanks!"
When we flush machine runs and waste goes properly but waterlevel goes high . during flush time the toiletbowl filled with water
Sounds like your external pipe may have a blockage tap the pipe to see if your hear a thud if it sounds clear check the toilet outflow pipe the same.. You may need to have your external pipes rodded.
Jan 08, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a saniflo. We were out, and our babysitter (who isn't familiar with saniflos) was in the bathroom and suddenly she said water was flooding out of the toilet - she said she had heard a loud noise...
Mar 11, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a saniflo and when we flush the toilet the pump does not switch off we are having to switch off at the main switch any idea's?
the connection between pump and outflow pipe is cracked under the elbow/backflow preventer has a rubber connection take backflow elbow out clean the rubber under it if ther is a crack in it the water keeps cycling back in tank so it thinks it is always full
Nov 17, 2010 | Saniflo Macerating Pump Toilet Waste Water...
I have a saniflo toilet installed in my attic. The pipe runs accross under the roof and is connected to the sewerage pipe for the bathroom on the first floor. What toilet paper should I - use -2-ply or...
Oct 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My daughter flushed he winter hat down the toilet. How do i get it out?
Kids eh?
.. I had my son flush LOTS of wipes down ours ...
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Feb 09, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Hi i'm pretty sure my son has just flushed a baby wipe down the toilet and now my saniflo is making strange noises and doesn't appear to be working properly, how can i check if the wipe has become tangled...
Hi, Had this myself with my son a while back!
Feb 08, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
I thought my macerator toilet must be blocked as it wasn't emptying in the bowl and when I flushed again the water (and waste) filled more into the bowl and leaked out of the top of the macerator spilling...
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Hope this helps a little bit.
Mark
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
The toilet was installed under the stairs a year ago and has hardly been used - the bowl keeps filling after flushing and overflows, I cant shut it off. It flooded the down stairs twice now - all over...
Oct 17, 2009 | Saniflo SaniBest-Round SaniBest Macerator...
Looking at the Saniflow - I have water leaking right hand base
It should be a simple solution. The seal from the toilet to the piping has failed and needs to be replaced.You are probably looking at a parts cost of less than 20 bucks if you buy it yourself.
Aug 29, 2009 | Home
Water leak from turboflush saniflo
water inlet pipe blows off when toilet is flushed
Nov 11, 2008 | Saniflo 013/005/007 Sanibest Toilet with...
Home Logo
106 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
