Question about Splendide 2100 Vented Washer-Dryer
Diplomat hja8703 Is there a lint catcher that needs periodically cleaning as with most dryers?
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
Is there a way to access the area under the removable lint catcher or should I just use a hanger
I have successfully taken the front of that off and cleaned it out. However, it isn't easy and I could see where it may result in a broken lint catch if not careful. After taking the front panel off - which is a pain in and of itself - you will need to carefully go around the lint catcher and separate it. It is in two halves that are held together by catches all around.
Sep 25, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
BOSCH WTE84100 CONDENSOR DRYER .will not start .Power display on and flashing ,all filter are clean, but machine beeps when try to start.
Two Beeps means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Aug 15, 2011 | Bosch Dryers
Clothes are now taking much longer to dry. I have cleaned the dryer vent & vent hose. ( all the way to the roof as I did once before that rectified the problem then.) Wet lint is around the door and...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
Flame goes off
First make sure that your exhaust pipe going outside is completely clear. Also you may need to clean the lint out of the drier. If you take the lint catcher assembley off on the inside, ther will be alot of lint inside. Just clean out what you can by hand, then vacuum out the rest. This should take care of your problem.
Jun 03, 2009 | Kenmore 74602 Gas Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Splendide 2100 Vented Washer-Dryer Logo
59 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
