Question about Linksys Wireless-N Home Router WRT120N - wireless router - 802.11b/g/n draft
Not connecting How to get connect to internet using PPPoE?
    Problem Solver:
  • 16 Answers
What to insert for PPPoE Service name to connect to internet
PPPoE stands for Point-to-Point Protocol over Ethernet, it's basically authentication for ISPs that use Usernames and Passwords to get you connected to the internet. If your ISP uses PPPoE you'll have to change the 360's settings to connect to the Xbox Live service.
Your PPPoE info should have been given to you when you signed up for your internet service(some ISPs even print the info somewhere on your hub/modem), otherwise you'll have to call them up and get the info from them. It's also important to know that if you're ISP doesn't use PPPoE you should leave these settings blank on your 360 or it won't connect.
Since you haven't connected to the live yet I'll assume you're still on the older dashboard so it should go like this:
1. Move to the System area of the Xbox dashboard.
2. Select Network Settings.
3. Select Edit Settings.
4. On the Additional Settings tab, select PPPoE Settings.
5. Use the on-screen keyboard to enter the PPPoE information that was provided to you by your ISP.
6. Select Done.
7. Select Apply and Test when you are prompted to do this.
Sep 03, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
I've problem with my ADSL i can't access by wireless??? i don't know why???
Some DSL Internet Service Providers (ISPs) use Point to Point Protocol over Ethernet (PPPoE) Authentication to establish Internet connection with their end-users. This article will guide you in setting up the router's PPPoE feature.
NOTE: This article assumes that you already have the username and the password for your DSL Internet connection.
Step 1:
Access the router's web-based setup page. For instructions, click here
NOTE: If you're using a Mac, click here for instructions.
Step 2:
On the Setup tab, click the drop-down arrow for Internet Connection Type then, select PPPoE.
Step 3:
Enter the Username and the Password for your DSL Internet connection.
Step 4:
Select Keep Alive.
Step 5:
Click Save Settings.
Step 6:
Click the Status tab.
Step 7:
Verify that the Connection Type is PPPoE then, click Connect.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | Linksys WRT54G2 Wireless Router
Wat is my PPPoE user name and passeord?
Hi It is the connection type of your internet service provider. If your internet depends on user and password then it needs pppoe . for that you need to configure router in pppoe mode but you can also create pppoe connection on your computer so just need to enter user and password of ppoe on computer then you can use internet on that computer. Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Step 1
Step 2
Step 3
Step 4
Step 5
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
New dir 625 with DSL-cat5 connection and NO internet on status.
If it keeps on trying to connect to PPPoE, try not to use PPPoE setting. Use Automatic Configuration or DHCP connection type.
Jun 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Linksys Wireless-N Home Router WRT120N - wireless router - 802.11b/g/n draft Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
